Hi All,
Updated to 22.12.3 from a clean install of 22.12.2.
Prior to the upgrade I was using S3 storage. I see that is now deprecated, but still exists within TrueNAS.
Followed the guide here:
1st issue:
You cannot set the storage path. I had to go back to the built-in S3 config and point it to another path and save it before I could set the storage path for MinIO Enterprise. The documentation needs to be updated.
www.truenas.com
2nd Issue:
Container never starts, even tried using ports 9000/9001 vs 30000/30001, no difference.
minio2023-03-24_1.0.11Up to date
Used Ports:30000\TCP, 30001\TCP
Status:DEPLOYING
Pods:1
Deployments:1
Statefulsets: 0
Catalog:
Truenas
Train:
Enterprise
Item Name:minio
Container Images
My Older S3 Config:
The Path:
S3 Turned off:
I'm migrating from the old built-in S3 via the instructions.
Tried redeploying, rebooting, no go. Is this broken? If so is S3 (built-in) still okay to use? It's not a huge deal, I was using it to send over nightly backups of my Synology NAS, but yet again I run into issues where the guide doesn't work, or no one seems to have tested it since the guide was written/product released. Sorry for venting, but either I'm missing something stupid or no one confirmed this actually works.
Thanks,
Scott
1st issue:
TrueNAS Apps Market
This website describes the standalone applications that are available to deploy within TrueNAS for an enhanced user experience and functionality.
2nd Issue:
Status:DEPLOYING
Pods:1
Deployments:1
Statefulsets: 0
Catalog:
Truenas
Train:
Enterprise
Item Name:minio
Container Images
Application Events 2023-06-18 14:23:44 Back-off restarting failed container 2023-06-18 14:23:41 Add eth0 [172.16.0.7/16] from ix-net 2023-06-18 14:23:41 Container image "minio/minio:RELEASE.2023-03-24T21-41-23Z" already present on machine 2023-06-18 14:23:41 Created container minio 2023-06-18 14:23:41 Started container minio 2023-06-18 14:23:40 Scaled up replica set minio-f6f866c4d to 1 2023-06-18 14:23:40 Created pod: minio-f6f866c4d-94cdh 2023-06-18 14:23:40 Successfully assigned ix-minio/minio-f6f866c4d-94cdh to ix-truenas 2023-06-18 14:23:39 Scaled down replica set minio-55879d6665 to 0 from 1 2023-06-18 14:23:39 Deleted pod: minio-55879d6665-8mbk5 2023-06-18 14:23:10 Back-off restarting failed container 2023-06-18 14:23:08 Created container minio 2023-06-18 14:23:08 Started container minio 2023-06-18 14:23:07 Add eth0 [172.16.0.6/16] from ix-net 2023-06-18 14:23:07 Container image "minio/minio:RELEASE.2023-03-24T21-41-23Z" already present on machine 2023-06-18 14:23:06 Scaled up replica set minio-55879d6665 to 1 2023-06-18 14:23:06 Created pod: minio-55879d6665-8mbk5 2023-06-18 14:23:06 Successfully assigned ix-minio/minio-55879d6665-8mbk5 to ix-truenas 2023-06-18 14:19:54 Created container minio 2023-06-18 14:19:54 Started container minio 2023-06-18 14:19:53 Deleted pod: minio-7b56867ddf-tph7s 2023-06-18 14:19:53 Scaled down replica set minio-7b56867ddf to 0 from 1 2023-06-18 14:19:53 Add eth0 [172.16.0.5/16] from ix-net 2023-06-18 14:19:53 Container image "minio/minio:RELEASE.2023-03-24T21-41-23Z" already present on machine 2023-06-18 14:19:52 Scaled up replica set minio-7b56867ddf to 1 2023-06-18 14:19:52 Created pod: minio-7b56867ddf-tph7s 2023-06-18 14:19:52 Successfully assigned ix-minio/minio-7b56867ddf-tph7s to ix-truenas 2023-06-18 14:19:20 Scaled down replica set minio-77995d4f4f to 0 from 1 2023-06-18 14:19:20 Deleted pod: minio-77995d4f4f-x4ns2 2023-06-18 14:15:46 Back-off restarting failed container 2023-06-18 14:15:45 Container image "minio/minio:RELEASE.2023-03-24T21-41-23Z" already present on machine 2023-06-18 14:15:44 Created container minio 2023-06-18 14:15:44 Started container minio 2023-06-18 14:15:43 Successfully pulled image "minio/minio:RELEASE.2023-03-24T21-41-23Z" in 7.523795824s 2023-06-18 14:15:36 Pulling image "minio/minio:RELEASE.2023-03-24T21-41-23Z" 2023-06-18 14:15:35 Created container minio-install-permissions 2023-06-18 14:15:35 Started container minio-install-permissions 2023-06-18 14:15:34 Successfully pulled image "bash:4.4.23" in 1.784814646s 2023-06-18 14:15:33 Add eth0 [172.16.0.4/16] from ix-net 2023-06-18 14:15:33 Pulling image "bash:4.4.23" 2023-06-18 14:15:32 Scaled up replica set minio-77995d4f4f to 1 2023-06-18 14:15:32 Created pod: minio-77995d4f4f-x4ns2 2023-06-18 14:15:32 Successfully assigned ix-minio/minio-77995d4f4f-x4ns2 to ix-truenas
My Older S3 Config:
The Path:
S3 Turned off:
Thanks,
Scott
