SOLVED TrueNas Core and Plex (nothing)
JAFFRE
Hello everyone, I have a problem with Plex on TrueNas Core.
I did three mount points in :
"/iocage / jails / Plex / root / plex_media/audio"
"/iocage / jails / Plex / root / plex_media/videos"
"/iocage / jails / Plex / root / plex_media/photos"
and my files appear in windows explorer in the three mount points.
When I try to adjust Plex, the directories are empty. Can you help me, thank you
LarsR
You also have do add the databases in plex itself, otherwise plex does not know where to find your Media files
JAFFRE
This is what I'm trying to do, but the directories are empty
JAFFRE
Ok, found the solution. It was the permissions that was not good
ddaenen1
Actually, you do not need 3 mount points. Just one is enough. If you then create an SMB share from that dataset you can add as many directories as you want via Windows and Plex will see all of them. Just a hint...
But if they are separate datasets, not directories in the same dataset, the setup will only work like that.
JAFFRE
Data is on multiple hard drives
