ajbrehm
- Oct 17, 2020
I am currently running a small vSphere cluster at home using TrueNAS NFS as storage. This works absolutely fine. (Although I did have to change a setting about when to write files to disk in TrueNAS to make it anything but terribly slow.)
I wanted to replace the vSphere hosts with Hyper-V hosts.
Is there a way to make TrueNAS work as storage server for Hyper-V, preferably the same share used by vSphere?
I read somewhere that exporting as SMB does not work unless the SMB server is a Windows server. Hyper-V will refuse to use SMB shares, apparently. Is this a known problem? Is there a way around it?
Any ideas?
Any ideas?
