Sara
- Jun 26, 2022
Hello everyone, I found an article:
storagegaga.com
which shows that manual configuration of gluster should work ok. I have questions to be sure to Gluster specialists in Truenas :) i think but i'm not sure.
If I use command line commands like "sudo gluster XXX" from the command line (not CLI, but normal gluster commands), will:
- truenas will remember the gluster configuration in the configuration file so that it is not lost during e.g. system update or configuration transfer?
- if not, how to do it, I don't want to use trueCommand because it's experimental for now, and I would like to use gluster because I already have an old gluster environment that I can manage from the command line and I would like to recreate the same new gluster envoirment on truenas by normal classic commands, how to do it preferably without TrueCommand?
Thx :)
I built a 6-node Gluster cluster with TrueNAS SCALE - Storage Gaga
I haven’t had hands-on with Gluster for over a decade. My last blog about Gluster was in 2011, right after I did a proof-of-concept for the now defunct, Jaring, Malaysia’s first ISP (Internet Service Provider). But I followed Gluster’s development on and off, until I found out that Gluster was …...
Thx :)
