Glusterfs CLI on SCALE 22.02.2+ without and with TrueCommand is secure?
Sara
Hello Guys,
I have question about Glusterfs in TrueNAS Scale 22.02.2+.
1) Can i usage normal GlusterFS CLI command on TrueNas Scale safe? eg.
gluster volume create test-volume server3:/exp3 server4:/exp4
etc. command like as normal usage glusterfs? it is safe and compatible with TrueCommand?
I means TrueCommand or update TrueNas Scale not break Glusterfs managed by normal CLI by glusterfs?
2) Can i usage TrueCommand and Glusterfs CLI alternately. I like glusterfs command line and i see TrueCommand looks cool..
3) When i usage GlusterFS Native Commands all configuration is stored in TrueNas when i Update TrueNas or export/import configuration? (can i usage normal CLI gluster? it is safe?)
Thx :)
morganL
Captain Morgan
Administrator
No, you would need to use the TrueNAS CLI... it goes through the middleware and save the configuration.
It is a direct way of using the trueNAS API: https://www.truenas.com/docs/scale/api/
Sara
thx for info, gui is cool, but also the terminal, all my daily operations are done by trerminal, my partners use gui, are all gluster functions available in TrueNas CLI like eg CLI proxy?
