Back that NAS up
- Jun 27, 2022
Hi everyone,
Sorry but please bare with me. I have user uid 1000 'huser' and guid LocalGroup, which huser is part of. My SMB is setup with Admin Group = LocalGroup, Guest Account = huser.
I can log in on Windows under huser and connect to the share. It works great.
I installed Plex, Sab, Sonarr, Radarr, etc. I setup mounts (which is easy for me to think of as symbolic links) and that's not bad. But what confuses me is the ACLs. Since I have 1 dataset ('MyDataset'), under one vdev named 'vdev01'. So what I dont get is the ACLs between programs.
For instance. I download a video file in Sab, the file is set as owned by Sab. To get plex to see it, after I move it to the media folder from windows SMB, i have to re-run the ACL permissions for plex user, and let its permission rerun recursively.
Ditto with Sonnar and Radarr. Since both of them I want to scan my media, I need to point them to various media sub directories which are all owned by huser/localgroup. I don't understand how their mount points can also own the same paths.
I can solve anyone app, but doing so breaks another. I don't want to run them all in one jail either. Whats the solution? I'm looking in the forest but not seeing the trees. How do you set ACLs with multple users/groups to the same or similar mounts directories?
I'll add, I'm not against running the jails setup manually. I like doing that.
Thanks
Thanks
