- Dec 8, 2017
I just upgraded from 11.3-U4.1 to 12 RC1. I'm having some issues with iSCSI performance. Usually I can write a large files to my zvol at about 600MBps (the sustained write speed of my SLOG device) but now seems to be at about 14MBps. Reads are ok though at 1GBps.
ZVOL is mounted as an iSCSI disk in Windows 10. Test is done using file copy in explorer. Sync disabled. I have multiple SSD backed pools on different controllers. Same exact result for zvols on each.
SMB Copies to a dataset on the Pool go at 1GBps both directions.
Anyone ideas?
Anyone ideas?
