SOLVED TrueNAS 11.2 Pool disappeared after cross-country move. Many attempts at solving tried. Further Assistance Needed - Please.
PhoenixMike
Hello everyone,
After an unexpected cross country move, I am having grave problems with my NAS. Right before our move, I had finally migrated all my data from random drives and locations to the NAS and was just about to do an encrypted cloud backup. I believe in the 3-2-1 method of backups, but didn't get a chance to do it unfortunately due to the abrupt move. Additionally, I cannot locate the configuration file which was backed up after the move, which is highly unfortunate.
Obviously, the data is very valuable. I had everything from company documents for my small business to 20 years worth of children/family photos. Priceless, not just PLEX movies like some servers :). Any assistance would be GREATLY appreciated by my small family. I appreciate your time invested in me and this post!
Before the move, the NAS was working fine. Here are the hardware specs of the NAS pre-move.
  • Motherboard : SuperMicro X11SM-F
  • Bios : v1.0
  • Memory : 32768MB (reported in bios) / speed : 2133MHZ
  • Boot Drive : Transcend 64GB SSD SATA (TS64GSSD370S) in MB Slot - SATA0
  • HD : WD 4TB, QTY 7, RAID Configuration UNKN (sorry)
  • HD Controller & Network - Onboard to MB - MB Specs : https://www.supermicro.com/en/products/motherboard/X11SSM-F
I have scoured the forums to get ideas on how to troubleshoot before bringing the issue to the group here. I thank everyone in advance for any assistance you may be able to provide.
Solutions Attempted :
  • Upgrade MB Bios to latest version - v2.5 (build 11/26/20)
    • This was necessary to use TrueNAS 12.0-U6 as the new install would hang at CPU initialization. Works now.
  • Replaced SATA cord on Boot Drive with new SATA cable using same SATA0 slot on MB
  • Replaced SATA cord on Boot Drive to SATA/USB cable and used USB on MB and changed boot order (drive is seen)
    • Error : This is a FreeNAS data disc and can not boot system. System halted.
  • Installed TrueNAS 12.0-U6 on USB Flash Drive (temporary, I know it is not recommended) and inserted into MB USB slot.
    • Boots fine (after BIOS update)
    • Unable to "Import Pool" in GUI under Storage -> Pools -> Add -> Import Existing Pool -> No Encryption -> as the result is Null --
  • Tried the following in the TrueNAS 12.0-U6 CLI to no avail :
    • zpool import -f
    • zpool import -fF
    • zpool import -fm
    • zpool import -f -m
    • zpool import -fFX
    • zpool import -fFX -m
    • zpool import -fmFX
    • zpool import -d /dev
    • all return no pools available to import
  • zpool list :
  • zpool status :
  • zbd -1 /dev/ada0p2
  • ls -l /dev/gptid
  • zfs list
    ee1ef59f-f231-ba25-ea35-41bd773c3557
  • glabel status
841d868f-190b-af1e-d364-1da2f1f61ece
  • gpart list ada0
83a3a8f7-ecf0-5e8c-06fe-7687beb70aca
PhoenixMike
  • zdb -l /dev/gptid/<rawuuid>
575427ab-cebd-eb6f-5833-a72d3853e730
  • Tried the same with ada1p2, ada2p2, and so on.
  • gpart show
a7415a92-31a9-742b-5996-3c3abec2f49f
dee6a33b-d57e-34df-a2c4-5148c3e16b52
a4092ce5-c67a-e9c2-8ed2-6da27fef90f0
Any attempts to help me resolve this issue would be greatly appreciated in advance. Thank you for your time and expertise!
In Deep Gratitude,
PhoenixMike
PhoenixMike
Apologies for all the screenshots. I tried to cut/paste into CODE brackets but was unsuccessful.
PhoenixMike
I should also mention that the original OS was : FreeNAS 11.3
Sorry for the multiple posts, but I cannot edit original post....
PhoenixMike
Complete results of command : gpart show
Other troubleshooting / system info I could add :
- System was connected to UPS
- To the best of my knowledge system never experienced power interruption
- System always powered down properly
- System was working before move
- System never stored in heat even during move
- System offline for 8 months before setting back up
Connected Boot Drive (Transcend 64GB FreeNAS 11.3) to MAC using data recovery tool. The HD appears, but no "recoverable data" was found :
I feel like an ass for not executing my 3-2-1 backup strategy BEFORE the move -- just in case, but it was sudden.
Thank you all in advance for reading this far!
Samuel Tai
Was this a GELI-encrypted pool? I've only ever seen the zdb failed to unpack label warnings with GELI-encrypted pools.
PhoenixMike
This was 100% it.
Thank you for your assistance!
I was looking thru some old drives and was able to find the encryption key which, once imported, loaded the pools no problem.
Back up and running - now having issues with SMB and Mac. Will make a separate post.
Thanks Again!
