Are the disks in a pool? If yes, then you can backup your data, destroy pool and format as many disks as you can at once. There is no way around this. If these disks are inside a server, they will get super hot if you format all of them at once. To a point where your server might shutdown without proper cooling.If I want format and replace the discs one by one I have many ours of work.
Not related to this thread topic, you already have a thread open for your issue. As you said, your disks are fine.got a message as "Device not ready" when running any sg_ commands
I was following your troubleshooting steps that's why I commented on this thread. My original disks are fine, the new ones are not since I'm unable to move past "device not ready" messageNot related to this thread topic, you already have a thread open for your issue. As you said, your disks are fine.![]()
I thought you have already one open, my bad. "device not ready" means the disk is defective, or there is an issue with the way you connect your disk, or with your controller. Time to open your own thread for that issue, this thread is related to badly formatted disks fixes only.BTW, what do you mean I already have a thread open?
got a message as "Device not ready" when running any sg_ commands. Any hint on how to troubleshoot this? I'm on a DL380Gen8 with P420i in HBA mode.
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.79+truenas] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Vendor: IBM-D050 Product: ST6000NM0014 Revision: BC7B Compliance: SPC-4 User Capacity: 6,001,175,126,016 bytes [6.00 TB] Logical block size: 4096 bytes Formatted with type 2 protection 8 bytes of protection information per logical block LU is fully provisioned Rotation Rate: 7200 rpm Form Factor: 3.5 inches Logical Unit id: 0x5000c5008e590dc7 Serial number: S4D090T60000K603GMT4 Device type: disk Transport protocol: SAS (SPL-3) Local Time is: Wed Jan 4 22:47:58 2023 EET SMART support is: Available - device has SMART capability. SMART support is: Enabled Temperature Warning: Enabled
root@truenas[~]# sg_readcap -l /dev/sdk Read Capacity results: Protection: prot_en=1, p_type=1, p_i_exponent=0 [type 2 protection] Logical block provisioning: lbpme=0, lbprz=0 Last LBA=1465130645 (0x57541e95), Number of logical blocks=1465130646 Logical block length=4096 bytes Logical blocks per physical block exponent=0 Lowest aligned LBA=0 Hence: Device size: 6001175126016 bytes, 5723166.6 MiB, 6001.18 GB, 6.00 TB
Instructions are provided into OP, how to fix the issue. Taking a disk offline and fixing it will not break anything in your raidz3 pool.Hi, after update from core to scale (Bluefin) i have the same problem.
And i got some strange error. any idea? i have tried with --six(from another forum suggestion, didn't help)Instructions are provided into OP, how to fix the issue. Taking a disk offline and fixing it will not break anything in your raidz3 pool.
root@truenas[~]# time sg_format -vFf 0 -s 512 /dev/sda IBM-D050 ST6000NM0014 BC7B peripheral_type: disk [0x0] PROTECT=1 << supports protection information>> Unit serial number: S4D090ZD0000K601HQC0 LU name: 5000c5008e58e757 mode sense(10) cdb: [5a 00 01 00 00 00 00 00 fc 00] Mode Sense (block descriptor) data, prior to changes: number of blocks will max out, set <<longlba>> mode sense(10) cdb: [5a 10 01 00 00 00 00 00 fc 00] <<< longlba flag set (64 bit lba) >>> Number of blocks=1465130646 [0x57541e96] Block size=4096 [0x1000] mode select(10) cdb: [55 11 00 00 00 00 00 00 24 00] mode select(10): Fixed format, current; Sense key: Illegal Request Additional sense: Invalid field in parameter list Field replaceable unit code: 17 Sense Key Specific: Error in Data parameters: byte 21 bit 7 Try MODE SELECT again with SP=0 this time mode select(10) cdb: [55 10 00 00 00 00 00 00 24 00] mode select(10): Fixed format, current; Sense key: Illegal Request Additional sense: Invalid field in parameter list Field replaceable unit code: 17 Sense Key Specific: Error in Data parameters: byte 21 bit 7 MODE SELECT command: Illegal request, type: sense key, apart from Invalid opcode sg_format -vFf 0 -s 512 /dev/sda 0.00s user 0.00s system 1% cpu 0.139 total
The output:What's the output for:
Code:# openSeaChest_Info -id /dev/sda
root@truenas[~]# openSeaChest_Info -id /dev/sda ========================================================================================== openSeaChest_Info - openSeaChest drive utilities - NVMe Enabled Copyright (c) 2014-2022 Seagate Technology LLC and/or its Affiliates, All Rights Reserved openSeaChest_Info Version: 2.0.0-2_2_1 X86_64 Build Date: Dec 13 2022 Today: Thu Jan 5 00:38:31 2023 User: root ========================================================================================== /dev/sg2 - ST6000NM0014 - S4D090ZD0000K601HQC0 - SCSI Vendor ID: IBM-D050 Model Number: ST6000NM0014 Serial Number: S4D090ZD0000K601HQC0 Firmware Revision: BC7B World Wide Name: 5000C5008E58E757 Drive Capacity (TB/TiB): 6.00/5.46 Temperature Data: Current Temperature (C): 37 Highest Temperature (C): Not Reported Lowest Temperature (C): Not Reported Power On Time: 5 years 19 days 8 hours 36 minutes Power On Hours: 44264.60 MaxLBA: 1465130645 Native MaxLBA: Not Reported Logical Sector Size (B): 4096 Physical Sector Size (B): 4096 Sector Alignment: 0 Rotation Rate (RPM): 7200 Form Factor: 3.5" Last DST information: Time since last DST (hours): 0.60 DST Status/Result: 0x0 DST Test run: 0x1 Long Drive Self Test Time: 10 hours 43 minutes Interface speed: Port 0 (Current Port) Max Speed (GB/s): 12.0 Negotiated Speed (Gb/s): 6.0 Port 1 Max Speed (GB/s): 12.0 Negotiated Speed (Gb/s): Not Reported Annualized Workload Rate (TB/yr): 82.63 Total Bytes Read (TB): 311.36 Total Bytes Written (TB): 106.15 Encryption Support: Not Supported Cache Size (MiB): Not Reported Read Look-Ahead: Not Supported Write Cache: Disabled SMART Status: Good ATA Security Information: Not Supported Firmware Download Support: Full, Segmented, Deferred Number of Logical Units: 1 Specifications Supported: SPC-4 SAM-5 SAS-3 SPL-3 SPC-4 SBC-3 Features Supported: Protection Type 1 Protection Type 2 [Enabled] Application Client Logging Self Test Automatic Write Reassignment [Enabled] Automatic Read Reassignment [Enabled] EPC Informational Exceptions [Mode 4] Translate Address Format Unit Sanitize Adapter Information: Vendor ID: 1000h Product ID: 0087h Revision: 0005h
# openSeaChest_FormatUnit -d /dev/sda --stopOnListError --protectionType 0 --formatUnit 512 --poll
First i got@BulgarianHealer, your SAS drive does not support SBC4, so you cannot use a fast format. Let's try this command, specific for SAS drives:
Code:# openSeaChest_FormatUnit -d /dev/sda --stopOnListError --protectionType 0 --formatUnit 512 --poll
If you get an error, post the output.
root@truenas[~]# openSeaChest_FormatUnit -d /dev/sda --stopOnListError --protectionType 0 --formatUnit 512 --poll ========================================================================================== openSeaChest_Format - openSeaChest drive utilities - NVMe Enabled Copyright (c) 2014-2022 Seagate Technology LLC and/or its Affiliates, All Rights Reserved openSeaChest_Format Version: 2.2.1-2_2_1 X86_64 Build Date: Dec 13 2022 Today: Thu Jan 5 01:21:15 2023 User: root ========================================================================================== /dev/sg2 - ST6000NM0014 - S4D090ZD0000K601HQC0 - SCSI Format Unit You must add the flag: "this-will-erase-data" to the command line arguments to run a format unit. e.g.: openSeaChest_Format -d /dev/sg? --formatUnit current --confirm this-will-erase-data
root@truenas[~]# openSeaChest_FormatUnit -d /dev/sda --stopOnListError --protectionType 0 --formatUnit 512 --poll --confirm this-will-erase-data ========================================================================================== openSeaChest_Format - openSeaChest drive utilities - NVMe Enabled Copyright (c) 2014-2022 Seagate Technology LLC and/or its Affiliates, All Rights Reserved openSeaChest_Format Version: 2.2.1-2_2_1 X86_64 Build Date: Dec 13 2022 Today: Thu Jan 5 01:22:34 2023 User: root ========================================================================================== /dev/sg2 - ST6000NM0014 - S4D090ZD0000K601HQC0 - SCSI Format Unit Format Unit Failed!
--stopOnListError
sets the stop format bit in a format unit. If the device cannot locate or access an existing primary or grown defect list, the format will stop and return with an error. Can you try it without it?# openSeaChest_FormatUnit -d /dev/sda --protectionType 0 --formatUnit 512 --poll --confirm this-will-erase-data
The disk is attached to the backplane(BPN-SAS826A SAS2), the backplane is connected to the expander(Intel RES2SV240) and the expander is connected to the LSI 9217-8I.How is the disk attached?--stopOnListError
Code:# openSeaChest_FormatUnit -d /dev/sda --protectionType 0 --formatUnit 512 --poll --confirm this-will-erase-data
root@truenas[~]# openSeaChest_FormatUnit -d /dev/sda --protectionType 0 --formatUnit 512 --poll --confirm this-will-erase-data ========================================================================================== openSeaChest_Format - openSeaChest drive utilities - NVMe Enabled Copyright (c) 2014-2022 Seagate Technology LLC and/or its Affiliates, All Rights Reserved openSeaChest_Format Version: 2.2.1-2_2_1 X86_64 Build Date: Dec 13 2022 Today: Thu Jan 5 01:51:39 2023 User: root ========================================================================================== /dev/sg2 - ST6000NM0014 - S4D090ZD0000K601HQC0 - SCSI Format Unit Format Unit Failed!
Open a new thread, there are a lot of smart people here on forums who have experience with backplanes and your LSI card. Once you get an answer if Scale kernel behaves with your hardware, try to get an answer on STH or r/homelab and post all troubleshooting commands you ran, then update us in this thread with the fix for your formatting issue. I'll add it to the guide.The disk is attached to the backplane
# openSeaChest_Erase -d /dev/sda --sanitize info
Okay, i will open a new thread tomorrow because it's getting too late for me. :)Open a new thread, there are a lot of smart people here on forums who have experience with backplanes and your LSI card. Once you get an answer if Scale kernel behaves with your hardware, try to get an answer on STH or r/homelab and update us with the fix for your formatting issue. I'll add it to the guide.
I'm curious what's the output for:
Code:# openSeaChest_Erase -d /dev/sda --sanitize info
root@truenas[~]# openSeaChest_Erase -d /dev/sda --sanitize info ========================================================================================== openSeaChest_Erase - openSeaChest drive utilities - NVMe Enabled Copyright (c) 2014-2022 Seagate Technology LLC and/or its Affiliates, All Rights Reserved openSeaChest_Erase Version: 3.0.3-2_2_1 X86_64 Build Date: Dec 13 2022 Today: Thu Jan 5 02:09:38 2023 User: root ========================================================================================== /dev/sg2 - ST6000NM0014 - S4D090ZD0000K601HQC0 - SCSI Sanitize The following sanitize commands are supported: Overwrite --sanitize overwrite
