Trouble installing freenas on my machine
hello everyone, i'm new to this OS and to linux in general, and i was trying to install freenas 11.2u2 but it seems that the usb stick gets corrupted each time rufus finishes preparing it, i tried downloading the iso multiple times and checked the checksum.
later i tried to install the 11.1u7 and the bootable usb looked fine but after installing the OS to my machine i keep getting a grub unknown filesystem error and i was wondering if i was doing something wrong, any help is appreciated :)
machine specs:
intel core i7
8gb ram ddr3
500 gb hhd
I was planning to use it as personal data storage/media library (things like plex), i own a qnap that just isnt powerful enough to support even a single full hd stream transcode, hence why i wanted to try and see how a machine with freenas did in comparison.
I could post step-by step photos of what i am trying to do if that would be of any help.
JokeRBY
Same here. Rufus 3.4 is used to create bootable stick.
There is log from rufus:
Scanning image...
ISO analysis:
  Image is an ISO9660 image
Disk image analysis:
  Image has an unknown Master Boot Record
  Image is a bootable disk image
ISO label: 'FREENAS'
  Size: 569.0 Мб (Projected)
  Note: File on disk is larger than reported ISO size by 300 Кб...
This ISOHybrid is not compatible with any of the ISO boot methods we support
Using image: FreeNAS-11.2-U2.1.iso (572.5 Mb)
Found USB 2.0 device 'ADATA USB Flash Drive USB Device' (125F:C08A)
Using autorun.inf label for drive F: 'FreeNAS'
Found USB 3.0 device 'ADATA USB Flash Drive USB Device' (125F:312B)
2 devices found
No volume information for drive 0x8b
Disk type: Removable, Disk size: 16 Gb, Sector size: 512 bytes
Cylinders: 1886, Tracks per cylinder: 255, Sectors per track: 63
Partition type: MBR, NB Partitions: 0
Disk ID: 0x753377DB
Drive has a Windows 7 Master Boot Record
2 devices found
Disk ID: 0x753377DB
Format operation started
Requesting disk access...
Will use 'E:' as volume mountpoint
Deleting partitions...
No partition to delete on disk '\\?\PhysicalDrive11'
Opened \\.\PhysicalDrive11 for exclusive write access
Writing Image...
2 devices found
Partition type: MBR, NB Partitions: 1
Disk ID: 0x753376F1
Drive has an unknown Master Boot Record
Partition 1:
  Type: GPT Protective MBR (0xee)
  Size: 572.5 MB (600258048 bytes)
  Start Sector: 1, Boot: No
2 devices found
Disk ID: 0x753376F1
Partition 1:
2 devices found
Disk ID: 0x753376F1
Partition 1:
11.2, 11.2U1, 11.2U2, 11.2U2.1 - same
11.1U7 - no problem
It might not be related, but would you mind following the forum guidelines regarding hardware and part numbers? For example, which motherboard are you using, which exact CPU, etc. You can edit your post above with the extra details. It may make a difference and may encourage other folks to be more responsive. :)
