Running Scale 22.12, with two NIC's (first is 1Gb Ethernet)- the one not allowing static IP. First nic on the board is enp7s0, that I built the system connected to a non tagged port on the switch, with a dhcp address and I was off to the races. I added in enp4s0 a 10G sfp+ card with a vlan interface (tagged-99), with a static IP - that one works fine, (on another management vlan) in addition to the 1g ethernet. enp7s0 is using dhcp, and I would like to static address it, so I added an alias in the GUI, and set the IP and mask bits, and when I go to test settings, and it comes back to the dhcp config.
The address is open, but the non tagged interface insists on the dhcp address. The default route is on the non tagged interface (enp7s0), and I have set a static route to the 0.0 network - which is the management vlan. When I disable dhcp and go to test, both NIC's drop out off the network, on both network segments. When it is dhcp everything communicates fine.
If anyone has ran through this drill, let me know. I read a few others issues, but I have tried, tested, and verified both networks are working, just won't take the static v4 address. Not using anything with ipv6. Everything else is running like a clock, just this goofy interface IP. Even tried rebooting it, as I was still configuring storage. Do I need to disable all shares before changing addresses? The static management vlan I thought was solid before attempting to change the 1g interface in hopes of having a backup out of band static interface before I start moving larger files. But will leave it dhcp for now, just one of the last details. Thanks for such a cool storage platform!
