Hi everyone, I just set up my freenas 8 box (64 bit) today and I'm trying to get transmission to work. I've set up a jail where the ip gateway is 192.168.1.11 and the gobal config gateway is 192.168.1.10. I can access the Web GUI for transmission just fine through the default port. However, when I try downloading a torrent, it won't even start. It tries, but never downloads anything. I check the network config from trans web gui, and I see: Port is Closed. I am using the default port. Also on my router, I have the 51413 port forwarded to the jail ip (192.168.1.11)
Also, I only have one network interface set up (only one NIC on the machine) and it is set up for the 192.168.1.10. Not sure if that matters, would I need one for the jail?
Can anyone please help me? Thanks for any help in advance!
