Gavin
- Aug 8, 2013
The trackers are fine. I can download with uTorrent on my computer, but Transmission won't connect to them. They either say "Connection failed" or "Could not connect to tracker. Transmission was set up properly before and was working. I guess this happened about 2 weeks ago because some shows failed to download.
I didn't change any setting or configuration. When I download with uTorrent onto my computer, Transmission will find it and connect to local.
What steps should I take to figure out what's wrong? Transmission is properly port forwarded through my router. I noticed that there is an update for the plugin.
I am running transmission-2.82-amd64 on FreeNAS-9.2.1.8-RELEASE-x64.
