Transmission permissions problem
George51
Member
I have manually set up a jail and installed Transmission. I've added groups to the jail so that it has permission to write to the folder I have added via storage.
It works fine, it can download fine. However. Whenever the jail is restarted, the folder that the downloads go into has its permissions changed to transmission:transmission, which interestingly breaks transmission. Any torrents that were downloading complain and stall, and it won't download anything new.
When I reset the permissions back to nobody:Dler (where Dler is the group that i've added to the transmission jail and added to the transmission user) and force restart of all the torrents they all start working again and I can get new torrents fine.
So somewhere there is a permissions issue, but where do I start to debug this?
Cheers
dureal99d
Member
Good morning!!
Are you using nfs or samba shares? and if you are using either did you create your folder thru the storage tab or in the file manager of either operating system?
If you are using windows; create the folder thru the explorer and manage the permissions using windows explorer.
if you are using Linux - make sure you give the appropriate groups read write access via the permission setting of the Freenas gui.
I have found this way to be the best way to set up transmission and I've never had an issue in this way.
jerryone
Neophyte
Guys verry easy. Windows has no power over freenas!!!! No mount permision needed just STORAGE PROBLEM WHEN U WRITE!!!!! GO TO STORAGE UNDER JAILS U HAVE TRANSMISSION_1 GIVE THE PERMISION TO WRITE OWNER/GROUP/OTHER MARK UNIX AND CLICK CHANGE
Sent from my A0001 using Tapatalk
George51
Member
So its not that I can't write. I can write to the storage, my issue is everytime I restart the jail it for some reason turns the "download" folder to transmission:transmission
This seems to stop it accessing the files within (which are still nobody:DLer as expected)
The storage is a dataset created through the storage tab. I understand the permissions that it should be and it does work like I said, how do I stop transmission resetting the permissions on the folder when I restart the jail?
jerryone
Neophyte
U have tray to delelte all of what transmision have on freenas? And after clean reinstal storage!!! Jail!!! Plagins!!! Everything?
George51
Member
Sorry I think you've misunderstood me. I do not want to delete transmission, it is working as advertised. I am using set groups for the reason that I have multiple jails involving different datasets, some overlapping and I don't want un-needed access across them. That and I only have a select group of users able to view these datasets anyway. I am not using any plugins, all of my jails are manually configured. My issue is a small issue related to permissions upon restarting the jail, I am sure it is something I've set up incorrectly. If anyone else can wade in and give me a steer on where to look for debugging this that would be appreciated.
George51
Member
Shameless bump, still having the permissions on just the folder changed whenever the jail (or transmission service) is restarted.
curufin
Newbie
I know this is an old thread, but I came upon it while researching this exact same issue and I wanted to share the solution I finally found.
Stop transmission with the command service transmission stop
Open the file /usr/local/etc/rc.d/transmission
About midway through the file, find the line:
: ${transmission_chown:=yes}
and change it to
: ${transmission_chown:=no}
Now you can restart transmission using service transmission start
Transmission will no longer change the owner and group of its download directory and files, and you will no longer slam your head against the desk in frustration.
Vaughn
Newbie
and change it to
Works like a charm. Thanks for this!
