Chris230291
- Mar 21, 2012
Hello. Today I noticed that transmission had stopped working. When I try to turn it on it tries for maybe two seconds, then the switch goes back to the "off" position. When this happens I do not see any messages at the top of the web GUI like you'd expect (some error occurred etc), nothing happens.
I have already tried resetting the permissions on the Jail volume/dataset (recursively) and rebooted but to no avail. I have also tried force starting the plugin with...
Doing that spits back...
If I look in /*jail name*/var/log/messages I see this...
Hopefully that log means something to you guys, if it does I'd appreciate a solution. It would be awesome if you could also explain maybe why that's happened too so I know for the future. Any help at all is appreciated.
Cheers,
Chris.
cd /usr/pbi/transmission-amd64/etc/rc.d/ ./transmission forcestart
Starting transmission. su: pam_start: system error
Mar 20 19:58:52 Transmission su: in openpam_check_desc_owner_perms(): /etc/pam.d/su: insecure ownership or permissions Mar 20 19:58:52 Transmission su: pam_start: system error Mar 20 19:58:52 Transmission root: /usr/local/etc/rc.d/transmission: WARNING: failed to start transmission
Cheers,
Chris.
