Transmission crashing
Chris230291
Hello. Transmission has started crashing on me and I can't figure out why. By crash I mean that I have to stop and then restart the Jail for it to work again. The plugin has worked faultlessly for a long time and has only just started to do this. I have already tried deleting the Jail and starting from scratch, but this hasn't fixed anything. If I check the Transmission log file I see that it's empty.
Can anyone suggest how to go about tackling this?
Cheers,
Chris.
Chris230291
Thanks for the reply.
If I look in there I see...
Jun  5 15:00:38 Server smbd[15528]: [2014/06/05 15:00:38.227297,  0] ../source3/lib/util_sock.c:941(matchname)
Jun  5 15:00:38 Server smbd[15528]:  matchname: host name/name mismatch: 10.0.1.9 != (NULL)
Jun  5 15:00:38 Server smbd[15528]: [2014/06/05 15:00:38.227426,  0] ../source3/lib/util_sock.c:1199(get_remote_hostname)
Jun  5 15:00:38 Server smbd[15528]:  matchname failed on 10.0.1.9
Jun  5 15:00:38 Server smbd[15529]: [2014/06/05 15:00:38.230918,  0] ../source3/lib/util_sock.c:941(matchname)
Jun  5 15:00:38 Server smbd[15529]:  matchname: host name/name mismatch: 10.0.1.9 != (NULL)
Jun  5 15:00:38 Server smbd[15529]: [2014/06/05 15:00:38.231009,  0] ../source3/lib/util_sock.c:1199(get_remote_hostname)
Jun  5 15:00:38 Server smbd[15529]:  matchname failed on 10.0.1.9
Jun  5 15:00:38 Server smbd[15530]: [2014/06/05 15:00:38.330931,  0] ../source3/lib/util_sock.c:941(matchname)
Jun  5 15:00:38 Server smbd[15530]:  matchname: host name/name mismatch: 10.0.1.9 != (NULL)
Jun  5 15:00:38 Server smbd[15530]: [2014/06/05 15:00:38.331036,  0] ../source3/lib/util_sock.c:1199(get_remote_hostname)
Jun  5 15:00:38 Server smbd[15530]:  matchname failed on 10.0.1.9
Jun  5 15:00:38 Server smbd[15531]: [2014/06/05 15:00:38.334342,  0] ../source3/lib/util_sock.c:941(matchname)
Jun  5 15:00:38 Server smbd[15531]:  matchname: host name/name mismatch: 10.0.1.9 != (NULL)
Jun  5 15:00:38 Server smbd[15531]: [2014/06/05 15:00:38.334436,  0] ../source3/lib/util_sock.c:1199(get_remote_hostname)
Jun  5 15:00:38 Server smbd[15531]:  matchname failed on 10.0.1.9
Thanks,
Chris.
Chris230291
Can anyone comment on whether or not those messages are related to my problem? I have no idea what they mean.
Cheers.
Chris.
Yatti420
Those aren't related.. What are your system specs? Do you only have one jail for transmission? What about network configuration?
Chris230291
Arh OK
My system is an Intel i5 860s on a Gigabyte GA-H55M-UD2H motherboard with 16GB of RAM.
Yes I have several Jails with a separate one for Transmission.
My router has a reservation (DHCP) for my server. My hostnam is "Server, my domain is "Local" and my default gateway is the IP of my router.
Thanks,
Chris.
D
dlavigne
Guest
When transmission stops responding, can you ping it by the jail's IP?
D
dlavigne
Guest
So, it's pingable... If you type sockstat on the FreeNAS system when transmission is not responding, is it showing the transmission service is still running?
Chris230291
Ok well I ran that and the only line that contained "Transmission" was this one...
921      transmissi 51890 13 dgram  -> /var/run/log
Chris230291
I think I have fixed it. I just used the GUI upgrade feature to reinstall FreeNAS 9.2.1.5 and so far all is going good.
