Transfering Files
Devilstompa
Hello I am new to Free Nas. I was wondering what is the fastest way to transfer 4tb over from computer to computer. Is it going to take days to do thank you.
Chris Moore
Hardware details? Some information about your situation is needed.
As Chris said, some details about your situation would help us give more detailed advice, but the easy answer is to send it over the network. If you can temporarily plug the disk containing this data into your FreeNAS box, you may be able to use the Import Disk feature in the web GUI--see the manual for details.
kdragon75
Just use the 100gb ethernet cards you mentioned in your post. Be sure to enable the RDMA on the specific model that you have.
kdragon75
