Hi folks,
this post is more like "I am thinking out loud" and wanting to hear your professional opinion and looking for some guidance.
This is what I am having and doing:
FreeNAS-9.10.2-U4, with one vdev of 8x4TB in RAID-Z2 (my "tank"). In addition, I have 2x4TB in mirror, called backup.
I also have configured a jail, and installed BORGBACKUP and B2 CLI.
As you can probably already tell, I am using BORG to backup my "tank" to "backup" for a local backup. Once the backup finishes, I sync the backup vdev to B2 Cloud Storage.
I find BORG dedup super efficient (3.77 TB become 1.35TB ...). This works quiet nicely, and BORG is very easy to use!
Now this is what I still want (and need) to do:
I also need an offsite backup, that is easily accessible to me, like taking a hard drive to my workplace, and having a hard drive in my NAS and rotating them weekly or so.
I have 2x2TB 2.5" hard drive in a removable enclose at my disposal. I could rsync the backup vdev to the 2TB HDD.
I was thinking of formatting the 2TB with ext2, but it generally not recommended. As well as UFS is not a good choice.
Than I though of using ZFS on single disc, however, it can create problems when corruption is occurring on the 2TB and I cannot import that single disc vdev anymore.
Now my final though is, to have a 3 disc mirror like 4TB:4TB;2TB. I know, that I will loose half of the capacity on the 4TB discs, but that is completely acceptable to me at this point, since all my data combined is ~1TB at the moment. It will take years for me to reach 2TB backup data.
What I would do, is remove the 2TB disc (disc_1) , (need suggestions from you how I can do this in a script), and resilve to the other 2TB disc (disc_2).
This is what I like about this idea:
- Resilver would be fast, since it would just copy data.
- I have the option to do scrubs and data corruption can be repaired (that would not be possible with a single disc vdev)
My biggest question at the moment is, how can I automate this in a script, aka, how can I automate the removal of a disk from a vdev and replace it with another disc.
These are the steps I would like to use for the backup procedure:
1: Backup data using BORG from tank to backup (note backup vdev would be 2TB large and have 3 discs in mirror)
2: Use B2 CLI to sync the backup vdev to cloud
3: run scrub (maybe only weekly)
4: remove (read umount) offsite disc_1 from vdev, so that I can physically remove the offsite disc_1 from the slot and insert the offsite disc_2.
5: Resilver offsite disc_2
I basically have automated step 1-3, but unsure on howto tackle the zfs vdev portion of this backup strategy. (essentially I would break a good vdev in order to be able to remove the disc ...)
One further note: I do not want to have to write commands in CLI before I can physically remove the disc to swap it with the second one. This has be automatic.
I can use the script to check if the disc has changed.
I will always know, what the status of my backup is (if it failed or completed, and if the offsite disc is still mounted) via status emails that I use in the script. So, before I remove the offsite disc from the NAS to replace it, I can check my emails and know, if the disc is still mounted or not.
This got a bit long and I hope its clear. If you need clarification etc. please ask.
Please do not suggest other software to backup. I have tried using snapshots for backup, and they are nice and work good, for reasons that would make this post to long and would be "off-topic", I decided not to use snapshots for backup (but I do use snapshots regularly and love them till death do us part, they have saved my butt in a big way more than once ...!).
I also have looked into using rsync to sync to a offsite location in town, but I do not have good options, so rotating disc is best for me right now.
Please have your comments, ideas and code coming ...
Thanks in advance, and cheers ...
Eddi
EDIT: Adjusted some numbers to be more accurate.
Eddi
