Timemachne fails on 11.3-U1
veverett
11.3-U1 has killed my TimeMachine shares, tried to re-connect them but I get OSStatus Error 2 I'm not using a samba setup.
Cheers Vin
veverett
I tore town the shares and re-shared them and it came back. Its possible something is not doing the share on boot.
Its backing up now so I will try a reboot, I have a fix for now. It should have just reshared after the upgrade :-(
After upgrading to 11.3 (and after rebooting FreeNAS), the AFP service *appeared* to be up, but Time Machine failed to connect with the OSStatus error 2.
I went into the FreeNAS "Services" and disabled and re-enabled AFP -- and was able to start Time Machine backup!
So, something in the AFP service is not coming up correctly...
veverett
Thanks Perry,
yes I had been doing that, its a bit tedious sosomething a bit odd with the boot order maybe.
Cheers Vin
Samuel Tai
veverett
Thanks Samuel, I tried it last night and it looks Ok.
Thanks for letting me know. FreeNAS is so cool.
