I hope so!Could be related to this bug:
https://jira.ixsystems.com/browse/NAS-105911
I hope so!
Is the SMB share also an NFS export? When an SMB share is also an NFS export we automatically configure the share to be as safe as possible in a mixed-protocol environment. These changes disable features that Time Machine relies on, hence "the selected network backup disk does not support the required capabilities".
We set the following and so you'll need to unset via auxiliary parameters on the share in question:How do I override this behavior. The share must be available for both NFS (Crashplan) and SMB TimeMachine. I have no worry of corruption since the NFS share is read-only unless I need to do a restore from the cloud.
pc[share["name"]].update({
"strict locking": "yes",
"level2 oplocks": "no",
"oplocks": "no"
})user@freenas[~]# testparm -s
Load smb config files from /usr/local/etc/smb4.conf
Loaded services file OK.
Server role: ROLE_STANDALONE
smb4conf file
# Global parameters
[global]
aio max threads = 2
bind interfaces only = Yes
client NTLMv2 auth = No
disable spoolss = Yes
dns proxy = No
enable web service discovery = Yes
kernel change notify = No
load printers = No
logging = file
max log size = 51200
ntlm auth = ntlmv1-permitted
restrict anonymous = 2
server min protocol = NT1
server role = standalone server
unix extensions = No
fruit:nfs_aces = No
idmap config * : backend = tdb
allocation roundup size = 0
directory name cache size = 0
dos filemode = Yes
include = /usr/local/etc/smb4_share.conf
[Storage]
aio write size = 0
comment = smb Share
ea support = No
mangled names = illegal
path = /mnt/Tank/SMB
read only = No
vfs objects = fruit streams_xattr ixnas
nfs4:acedup = merge
nfs4:chown = true
fruit:resource = stream
fruit:metadata = stream
[timemachine_user1 Mojave]
aio write size = 0
comment = TM Backup Rachel
ea support = No
path = /mnt/Tank/timemachine_rachel
read only = No
vfs objects = fruit streams_xattr shadow_copy_zfs ixnas
nfs4:acedup = merge
nfs4:chown = true
fruit:volume_uuid = 96a9f83f-ec1a-408f-abe5-5e510d73934b
fruit:time machine = yes
[timemachine_user2 High Sierra]
aio write size = 0
ea support = No
path = /mnt/Tank/timemachine_yariv
read only = No
nfs4:acedup = merge
nfs4:chown = true
fruit:volume_uuid = a2402b1d-eb9b-4f79-8b8f-d25bc12da0ed
fruit:metadata = stream[global]
dns proxy = No
aio max threads = 2
load printers = No
printing = bsd
dos filemode = Yes
unix charset = UTF-8
log level = 1
obey pam restrictions = False
enable web service discovery = True
logging = file
ntlm auth = Yes
client ntlmv2 auth = No
fruit:nfs_aces = No
netbios name = freenas
netbios aliases =
workgroup = WORKGROUP
idmap config *: backend = tdb
include = /usr/local/etc/smb4_share.confI was having this issue on 12... and enabling the "Export recycle bin" setting seems to have resolved it.Since updating from 11.2 to 11.3 my mac (latest Catalina release) isn't able to backup to the time machine share anymore. The backup dialogue shows the following error: "the network backup disk does not support the required capabilities". I've already tried several things like deleting and recreating the share. The smb4.conf file does not contain a "fruit:time machine = yes" line. As soon as i reboot with the 11.2 version, time machine backups works like a charm. Does anyone have an idea what is going wrong here?
If it helps, here's the relevant part of myThis is driving me nuts!
I have tried all the above solutions, thanks to you all btw, but none are working.
testparm -s output:
~ sudo testparm -s
Weak crypto is allowed
# Global parameters
[global]
aio max threads = 2
dns proxy = No
load printers = No
logging = file
max log size = 5120
registry shares = Yes
server string = TrueNAS Server
fruit:nfs_aces = No
dos filemode = Yes
[TimeMachine]
comment = Time Machine SMB Volume
ea support = No
kernel share modes = No
path = /mnt/tanka/TimeMachine/%U
posix locking = No
read only = No
vfs objects = tmprotect fruit streams_xattr shadow_copy_zfs ixnas aio_fbsd
ixnas:default_user_quota = 1T
ixnas:zfs_auto_homedir = true
fruit:locking = none
nfs4:chown = true
Hi and thank you for the reply,If it helps, here's the relevant part of mytestparm -soutput:
Code:~ sudo testparm -s Load smb config files from /usr/local/etc/smb4.conf Loaded services file OK. Weak crypto is allowed Server role: ROLE_STANDALONE # Global parameters [global] aio max threads = 2 bind interfaces only = Yes disable spoolss = Yes dns proxy = No enable web service discovery = Yes kernel change notify = No load printers = No logging = file max log size = 5120 nsupdate command = /usr/local/bin/samba-nsupdate -g registry shares = Yes restrict anonymous = 2 server role = standalone server server string = TrueNAS Server unix extensions = No idmap config *: range = 90000001-100000000 fruit:nfs_aces = No idmap config * : backend = tdb directory name cache size = 0 dos filemode = Yes [TimeMachine] comment = Time Machine NFS Volume ea support = No kernel share modes = No path = /mnt/tanka/TimeMachine/%U posix locking = No read only = No vfs objects = tmprotect fruit streams_xattr shadow_copy_zfs ixnas aio_fbsd ixnas:default_user_quota = 1T ixnas:zfs_auto_homedir = true fruit:locking = none fruit:time machine = yes fruit:resource = stream fruit:metadata = stream nfs4:chown = true
