- Aug 16, 2011
I'm also having trouble with Time Machine on my Mac clients (OS versions 10.14.6 and 10.12.6). I can't confirm that they started exactly when I upgraded to 11.3, but it was at least close. Of note, I'm still on 11.3--if -U1 would be likely to have resolved this, let me know, but I'd rather not down the server right now if I don't have to. For right now, I'm trying to use the dan-tm2 share. The error shown on the screen is:
On the Mac:
On the NAS:
On the Mac:
dan@Dan-MacBook-Pro-2453 /etc dns-sd -B _adisk._tcp. Browsing for _adisk._tcp. DATE: ---Fri 20 Mar 2020--- 10:31:52.470 ...STARTING... Timestamp A/R Flags if Domain Service Type Instance Name 10:31:52.666 Add 2 5 local. _adisk._tcp. freenas2 10:31:52.781 Add 2 6 local. _adisk._tcp. freenas2 ^C dan@Dan-MacBook-Pro-2453 /etc dns-sd -L freenas2 _adisk._tcp. Lookup freenas2._adisk._tcp..local DATE: ---Fri 20 Mar 2020--- 10:33:12.611 ...STARTING... 10:33:12.782 freenas2._adisk._tcp.local. can be reached at freenas2.local.:9 (interface 6) sys=waMa=0,adVF=0x100 dk0=adVN=dan-tm2,adVF=0x82,adVU=6181d9b8-d126-4616-a3a0-eb4e7e273f54 dk1=adVN=emily-tm,adVF=0x81,adVU=fa71a85c-f3a4-4878-a110-8d9ce854693a dk2=adVN=dan-tm,adVF=0x81,adVU=657cea92-aa9c-4f57-a236-600adab54ba8 dk3=adVN=charlie-tm,adVF=0x81,adVU=965a2137-138a-4726-8314-7120f19e707a
On the NAS:
root@freenas2[~]# testparm -s Load smb config files from /usr/local/etc/smb4.conf Loaded services file OK. Server role: ROLE_STANDALONE # Global parameters [global] aio max threads = 2 bind interfaces only = Yes disable spoolss = Yes dns proxy = No enable web service discovery = Yes kernel change notify = No load printers = No logging = file map to guest = Bad User max log size = 51200 netbios name = FREENAS nsupdate command = /usr/local/bin/samba-nsupdate -g obey pam restrictions = Yes server min protocol = SMB2_02 server role = standalone server server string = FreeNAS Server unix extensions = No username map = /usr/local/etc/smbusername.map username map cache time = 60 workgroup = FAMILYBROWN idmap config *: range = 90000001-100000000 fruit:nfs_aces = No idmap config * : backend = tdb allocation roundup size = 0 directory name cache size = 0 dos filemode = Yes include = /usr/local/etc/smb4_share.conf [Documents] aio write size = 0 ea support = No guest ok = Yes hide dot files = No mangled names = illegal path = /mnt/tank/Documents read only = No vfs objects = shadow_copy_zfs zfs_space zfsacl fruit streams_xattr nfs4:acedup = merge nfs4:chown = true fruit:resource = stream fruit:metadata = stream [Houdini Backup] aio write size = 0 ea support = No mangled names = illegal path = /mnt/tank/houdini read only = No vfs objects = shadow_copy_zfs fruit streams_xattr nfs4:acedup = merge nfs4:chown = true fruit:resource = stream fruit:metadata = stream [Torrents] aio write size = 0 ea support = No mangled names = illegal path = /mnt/tank/torrents read only = No vfs objects = zfs_space zfsacl fruit streams_xattr nfs4:acedup = merge nfs4:chown = true fruit:resource = stream fruit:metadata = stream [Transmission] aio write size = 0 ea support = No guest ok = Yes mangled names = illegal path = /mnt/tank/transmission read only = No vfs objects = zfs_space zfsacl fruit streams_xattr nfs4:acedup = merge nfs4:chown = true fruit:resource = stream fruit:metadata = stream [Video] aio write size = 0 ea support = No guest ok = Yes level2 oplocks = No mangled names = illegal oplocks = No path = /mnt/tank/Video read only = No strict locking = Yes vfs objects = shadow_copy_zfs zfs_space zfsacl fruit streams_xattr nfs4:acedup = merge nfs4:chown = true fruit:resource = stream fruit:metadata = stream [homes] aio write size = 0 ea support = No mangled names = illegal path = /mnt/tank/dan/%U read only = No vfs objects = zfs_space zfsacl fruit streams_xattr nfs4:acedup = merge nfs4:chown = true fruit:resource = stream fruit:metadata = stream [dan-tm2] aio write size = 0 ea support = No mangled names = illegal path = /mnt/tank/dan-tm2 read only = No vfs objects = shadow_copy_zfs ixnas fruit streams_xattr nfs4:acedup = merge nfs4:chown = true fruit:volume_uuid = 6181d9b8-d126-4616-a3a0-eb4e7e273f54 fruit:time machine = yes fruit:resource = stream fruit:metadata = stream [media] aio write size = 0 comment = Non-video media ea support = No guest ok = Yes mangled names = illegal path = /mnt/tank/media read only = No vfs objects = shadow_copy_zfs zfs_space zfsacl fruit streams_xattr nfs4:acedup = merge nfs4:chown = true fruit:resource = stream fruit:metadata = stream [scripts] aio write size = 0 ea support = No guest ok = Yes mangled names = illegal path = /mnt/ssdpool/scripts read only = No vfs objects = shadow_copy_zfs zfs_space zfsacl fruit streams_xattr nfs4:acedup = merge nfs4:chown = true fruit:resource = stream fruit:metadata = stream [ubuntu-backup] aio write size = 0 ea support = No mangled names = illegal path = /mnt/tank/ubuntu-backup read only = No vfs objects = shadow_copy_zfs zfs_space zfsacl fruit streams_xattr nfs4:acedup = merge nfs4:chown = true fruit:resource = stream fruit:metadata = stream root@freenas2[~]#
