rawdrumandbass
- Jul 3, 2014
Evening all,
After reading through the extensive advice and support on this forum I think I have finally found a build that I am happy with.
However, I tend to overkill with regards to I.T. so would gladly take any feedback. I do like to future-proof where I can though which is probably the reason I overkill.
The main purpose for my build will be to store data, access this data physically and remotely, use with the Plex plugin to stream media across multiple devices and being used as a backup to my other PC's.
I was thinking of running some virtual machines from it but I think this will hog too much memory. I will most likely find new uses for it once I am fully set up and running.
I will be utilising RAIDZ2. RAM will be unbuffered.
So here are my thoughts:
Motherboard: ASRock E3C226D2I Server/Workstation Board
HDD's: WD Red 3 TB NAS Hard Drive: WD30EFRX (x6)
RAM: Kingston Technology ValueRam DDR3 1600 MHz ECC DIMM - 8 GB (x2)
Chassis: Fractal Design Node 304 Desktop
Processor: Intel Xeon E3-1230V3 3.3 GHz Processor
PSU: Corsair RM 550W Fully Modular 80+ Gold Power Supply
CPU Heatsink: Noctua NH-L12 Processor cooler
Fans: Noctua NF-A14 iPPC IP67 PWM 140mm Premium Quality Fan, ZALMAN ZM SF2 Shark’s Fin Blade 92mm Silent Fan Case fan (x2)
USB: Kingston Technology DataTraveler Locker+ G3 8GB with FreeNAS 9.2.1.5
I went quite high went the PSU as I read that utilising 50% will increase working life. However, like I said, I tend to overkill so this may be too high?
Any help would be welcomed. Thanks.
