danno
- Sep 3, 2012
I searched but didn't see my particular flavor of this issue mentioned yet in the forum. Sorry if it duplicates another post.
For many years now, I have been having this problem and decided to finally post about it.
It just happened today when I updated from TrueNAS-12.0-U5 to TrueNAS-12.0-U6, but also happened when I was running FreeNAS (11).
Here are basic system details:
PC is Lenovo Thinkserver TS140
Boot disk is a single 120 GB SSD
Server has 3 data drives (2 GB each) configured in RaidZ1
All 3 data drives are excluded from the boot sequence in the BIOS
That last statement above is key, because the problem is that after each update is applied using the
System - Update option in the GUI, the subsequent reboot gets hung up indefinitely with the subject error:
"This is a FreeNAS data disk and can not boot system. System halted"
The only way I can get the update to complete is to reboot the server (without changing any BIOS settings),
and the subsequent update will complete and boot successfully to the new update version of TrueNAS.
A few times, I have gone into the BIOS right after the error appears to confirm that the 3 data drives are
still excluded from the boot sequence (they are), and the only drive in the boot sequence is the 120 GB SSD (as expected).
I would like to be able to run an update all the way to completion without having to manually intervene
each time. Hoping there is an easy fix or workaround that I just haven't discovered yet.
