Hubertus Feindler
- Oct 30, 2015
One or more devices has experienced an error resulting in data corruption. Applications may be affected.
[root@freenas] ~# zpool status -vx
pool: vol0
state: DEGRADED
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: http://illumos.org/msg/ZFS-8000-8A
scan: scrub repaired 0 in 13h24m with 0 errors on Sun Jan 3 13:24:41 2016
NAME STATE READ WRITE CKSUM
vol0 DEGRADED 0 0 267
raidz2-0 DEGRADED 0 0 534
gptid/82695e5f-95c8-11e5-aa04-0015177b16ec DEGRADED 0 0 0 too many errors
gptid/83dc4ff5-95c8-11e5-aa04-0015177b16ec DEGRADED 0 0 0 too many errors
gptid/84b6d8f2-95c8-11e5-aa04-0015177b16ec DEGRADED 0 0 0 too many errors
gptid/8594258a-95c8-11e5-aa04-0015177b16ec DEGRADED 0 0 0 too many errors
gptid/8673fb54-95c8-11e5-aa04-0015177b16ec DEGRADED 0 0 0 too many errors
gptid/87555e48-95c8-11e5-aa04-0015177b16ec ONLINE 0 0 0
gptid/88344bf8-95c8-11e5-aa04-0015177b16ec DEGRADED 0 0 0 too many errors
vol0/zvol0:<0x1>
[root@freenas] ~# tw_cli
//freenas> show
Ctl Model (V)Ports Drives Units NotOpt RRate VRate BBU
c0 9650SE-16ML 16 11 11 0 1 1 WeakBat
//freenas> /c0 show
Unit UnitType Status %RCmpl %V/I/M Stripe Size(GB) Cache AVrfy
u0 SINGLE OK - - - 3725.28 RiW OFF
u1 SINGLE OK - - - 3725.28 RiW OFF
u2 SINGLE OK - - - 3725.28 RiW OFF
u3 SINGLE OK - - - 3725.28 RiW OFF
u4 SINGLE OK - - - 3725.28 RiW OFF
u5 SINGLE OK - - - 3725.28 RiW OFF
u6 SINGLE OK - - - 3725.28 RiW OFF
u7 SINGLE OK - - - 3725.28 RiW OFF
u8 SINGLE OK - - - 3725.28 RiW OFF
u9 SINGLE OK - - - 3725.28 RiW OFF
u10 SINGLE OK - - - 3725.28 RiW OFF
VPort Status Unit Size Type Phy Encl-Slot Model
p4 OK u0 3.63 TB SATA 4 - WDC WD40EFRX-68WT0N0
p5 OK u1 3.63 TB SATA 5 - WDC WD40EFRX-68WT0N0
p6 OK u2 3.63 TB SATA 6 - WDC WD40EFRX-68WT0N0
p7 OK u3 3.63 TB SATA 7 - WDC WD40EFRX-68WT0N0
p8 OK u7 3.63 TB SATA 8 - WDC WD40EFRX-68WT0N0
p9 OK u4 3.63 TB SATA 9 - WDC WD40EFRX-68WT0N0
p10 OK u5 3.63 TB SATA 10 - WDC WD40EFRX-68WT0N0
p11 OK u6 3.63 TB SATA 11 - WDC WD40EFRX-68WT0N0
p12 OK u8 3.63 TB SATA 12 - WDC WD40EFRX-68WT0N0
p13 OK u9 3.63 TB SATA 13 - WDC WD40EFRX-68WT0N0
p14 OK u10 3.63 TB SATA 14 - HGST HUS724040ALE640
Name OnlineState BBUReady Status Volt Temp Hours LastCapTest
bbu On Yes WeakBat OK OK 0 xx-xxx-xxxx
What can I do?
Hardware is Memory with no ECC Ram. The device is used as an ISCSI-Device attached to Xenservers.
pool: vol0
state: DEGRADED
vol0/zvol0:<0x1>
//freenas> show
//freenas> /c0 show
What can I do?
