The path '/mnt/volume' requires execute permission bit
falukky
I am try to install Transmission using this tutorial and after install start the plugin and go to Jails --> Add storage i have this message:
Also when choose my data set and the destination folder i have this errors:
How can i solve this and what does it means ?
What are your system specs?
falukky
Intel Core i3-4150
ASRock E3C224D2I Mini ITX Server Motherboard
Crucial 16GB (2 x 8GB) 240-Pin DDR3 SDRAM ECC Unbuffered DDR3 1600 (PC3 12800) Server Memory
6 x 2TB hard drive.
jgreco
Resident Grinch
It sounds like you've maybe twiddled with the permissions for /mnt/volume. Try turning on execute. Storage->Volumes->/mnt/volume->Change Permissions
falukky
Thanks the really helped but now all my torrents failed with Permissions denied error and i can see that no folder created, where i need to changed the permissions ?
jgreco
Resident Grinch
Make sure you've got read, write, and execute permissions set for /mnt/volume ... turning everything on is probably a good idea if you're having problems.
