SOLVED The Message ID: ZFS-8000-8A indicates corrupted data exists in the current pool
larencio88
Good Morning,
After a power outage, I am seeing this error appear.
        tank/.system/cores:<0x0>
All of my Data appears to be OK, but I am a little worried. I am not sure what this file is that is damaged.
[root@freenas ~]# zpool status -xv
  pool: tank
state: ONLINE
        corruption.  Applications may be affected.
action: Restore the file in question if possible.  Otherwise restore the
        entire pool from backup.
   see: http://illumos.org/msg/ZFS-8000-8A
  scan: scrub repaired 0 in 6h22m with 0 errors on Thu Feb 16 06:22:11 2017
        tank                                            ONLINE       0     0     0
          mirror-0                                      ONLINE       0     0     0
            gptid/728891ef-c1ed-11e6-8676-90e2ba10fb36  ONLINE       0     0     0
            gptid/73b26b53-c1ed-11e6-8676-90e2ba10fb36  ONLINE       0     0     0
            gptid/75887ab0-c1ed-11e6-8676-90e2ba10fb36  ONLINE       0     0     0
          mirror-1                                      ONLINE       0     0     0
            gptid/ef1ec14a-c1ed-11e6-8676-90e2ba10fb36  ONLINE       0     0     0
            gptid/a74d44ee-c7e2-11e6-83c0-90e2ba10fb36  ONLINE       0     0     0
            gptid/f3022fca-c1ed-11e6-8676-90e2ba10fb36  ONLINE       0     0     0
          mirror-2                                      ONLINE       0     0     0
            gptid/53daad39-c1ee-11e6-8676-90e2ba10fb36  ONLINE       0     0     0
            gptid/55c7424f-c1ee-11e6-8676-90e2ba10fb36  ONLINE       0     0     0
            gptid/718c0169-c728-11e6-8676-90e2ba10fb36  ONLINE       0     0     0
          mirror-3                                      ONLINE       0     0     0
            gptid/40382162-c714-11e6-8676-90e2ba10fb36  ONLINE       0     0     0
            gptid/4cfcec8d-c6fc-11e6-8676-90e2ba10fb36  ONLINE       0     0     0
            gptid/61623ed4-c606-11e6-8676-90e2ba10fb36  ONLINE       0     0     0
[root@freenas ~]#
Does anyone have a suggestion on how I should proceed.
SweetAndLow
Sweet'NASty
Restore the file or delete it. And get a ups so next time this doesn't happen to your important data.
larencio88
Just updated the specs in my signature, have a Supermicro X10SL7-F with onboard controller. The drives are a mixture of Toshiba, Seagate, and Western Digital 3.0 TB.
larencio88
Error message attached.
  • Screenshot from 2017-02-22 11:39:19.png
Jailer
Not strong, but bad
Are you running periodic smart tests?
larencio88
Yes, I have setup the SMART test schedule.
  • Screenshot from 2017-02-22 12:11:46.png
Jailer
Not strong, but bad
But have you checked your drive(s) to see if it is running? Post the output of smartctl -a /dev/da7 and place the output in code tags.
larencio88
Here is the output.
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:  Toshiba 3.5" DT01ACA... Desktop HDD
Device Model:  TOSHIBA DT01ACA300
Serial Number:  Y5FM2LTGS
LU WWN Device Id: 5 000039 fe3c8acd5
Firmware Version: MX6OABB0
User Capacity:  3,000,592,982,016 bytes [3.00 TB]
Sector Sizes:  512 bytes logical, 4096 bytes physical
Rotation Rate:  7200 rpm
Form Factor:  3.5 inches
Device is:  In smartctl database [for details use: -P show]
ATA Version is:  ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:  Wed Feb 22 12:55:54 2017 CST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x85) Offline data collection activity
  was aborted by an interrupting command from host.
Self-test execution status:  (  0) The previous self-test routine completed
  been run.
data collection:  (22222) seconds.
capabilities:  (0x5b) SMART execute Offline immediate.
  command.
  Self-test supported.
SMART capabilities:  (0x0003) Saves SMART data before entering
  power-saving mode.
Error logging capability:  (0x01) Error logging supported.
Short self-test routine
recommended polling time:  (  1) minutes.
Extended self-test routine
recommended polling time:  ( 371) minutes.
SCT capabilities:  (0x003d) SCT Status supported.
  SCT Data Table supported.
ID# ATTRIBUTE_NAME  FLAG  VALUE WORST THRESH TYPE  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate  0x000b  100  100  016  Pre-fail  Always  -  0
  2 Throughput_Performance  0x0005  139  139  054  Pre-fail  Offline  -  71
  3 Spin_Up_Time  0x0007  133  133  024  Pre-fail  Always  -  431 (Average 433)
  4 Start_Stop_Count  0x0012  100  100  000  Old_age  Always  -  32
  5 Reallocated_Sector_Ct  0x0033  100  100  005  Pre-fail  Always  -  0
  7 Seek_Error_Rate  0x000b  100  100  067  Pre-fail  Always  -  0
  8 Seek_Time_Performance  0x0005  124  124  020  Pre-fail  Offline  -  33
  9 Power_On_Hours  0x0012  100  100  000  Old_age  Always  -  4334
 10 Spin_Retry_Count  0x0013  100  100  060  Pre-fail  Always  -  0
 12 Power_Cycle_Count  0x0032  100  100  000  Old_age  Always  -  32
192 Power-Off_Retract_Count 0x0032  100  100  000  Old_age  Always  -  74
193 Load_Cycle_Count  0x0012  100  100  000  Old_age  Always  -  74
194 Temperature_Celsius  0x0002  166  166  000  Old_age  Always  -  36 (Min/Max 20/43)
196 Reallocated_Event_Count 0x0032  100  100  000  Old_age  Always  -  0
197 Current_Pending_Sector  0x0022  100  100  000  Old_age  Always  -  0
198 Offline_Uncorrectable  0x0008  100  100  000  Old_age  Offline  -  0
199 UDMA_CRC_Error_Count  0x000a  200  200  000  Old_age  Always  -  49
SMART Error Log Version: 1
ATA Error Count: 49 (device log contains only the most recent five errors)
  CR = Command Register [HEX]
  FR = Features Register [HEX]
  ER = Error register [HEX]
  ST = Status register [HEX]
Error 49 occurred at disk power-on lifetime: 4323 hours (180 days + 3 hours)
  ER ST SC SN CL CH DH
  84 51 c1 9f 6d ad 03  Error: ICRC, ABRT at LBA = 0x03ad6d9f = 61697439
  CR FR SC SN CL CH DH DC  Powered_Up_Time  Command/Feature_Name
  60 00 00 60 6d ad 40 00  05:38:57.828  READ FPDMA QUEUED
  60 00 00 60 6e ad 40 00  05:38:57.799  READ FPDMA QUEUED
  ea 00 00 00 00 00 00 00  05:38:57.776  FLUSH CACHE EXT
  60 00 00 f0 4a ac 40 00  05:38:56.559  READ FPDMA QUEUED
  60 00 00 f0 49 ac 40 00  05:38:56.531  READ FPDMA QUEUED
Error 48 occurred at disk power-on lifetime: 4317 hours (179 days + 21 hours)
  84 51 41 3f d3 ce 0f  Error: ICRC, ABRT at LBA = 0x0fced33f = 265212735
  60 00 00 80 d2 ce 40 00  00:09:37.597  READ FPDMA QUEUED
  60 00 00 00 1b d2 40 00  00:09:37.584  READ FPDMA QUEUED
  2f 00 01 10 00 00 00 00  00:09:37.579  READ LOG EXT
  60 00 00 00 1b d2 40 00  00:09:37.562  READ FPDMA QUEUED
  60 08 00 d8 39 cf 40 00  00:09:37.561  READ FPDMA QUEUED
Error 47 occurred at disk power-on lifetime: 4317 hours (179 days + 21 hours)
  84 51 f1 0f 1b d2 0f  Error: ICRC, ABRT at LBA = 0x0fd21b0f = 265427727
  60 08 00 70 10 0d 40 00  00:09:37.538  READ FPDMA QUEUED
  60 08 00 b0 39 cf 40 00  00:09:37.518  READ FPDMA QUEUED
  60 08 00 90 ba 50 40 00  00:09:37.490  READ FPDMA QUEUE
Error 46 occurred at disk power-on lifetime: 4317 hours (179 days + 21 hours)
  84 51 31 ef 2a ca 0f  Error: ICRC, ABRT at LBA = 0x0fca2aef = 264907503
  60 00 00 20 2a ca 40 00  00:09:37.387  READ FPDMA QUEUED
  60 00 00 20 29 ca 40 00  00:09:37.386  READ FPDMA QUEUED
  60 08 00 f8 28 ca 40 00  00:09:37.310  READ FPDMA QUEUED
  60 10 00 a8 74 50 40 00  00:09:37.282  READ FPDMA QUEUED
  60 08 00 a0 74 50 40 00  00:09:37.266  READ FPDMA QUEUED
Error 45 occurred at disk power-on lifetime: 4317 hours (179 days + 21 hours)
  84 51 a1 9f 99 c8 0f  Error: ICRC, ABRT at LBA = 0x0fc8999f = 264804767
  60 00 00 40 99 c8 40 00  00:09:37.159  READ FPDMA QUEUED
  60 08 00 00 92 0c 40 00  00:09:37.156  READ FPDMA QUEUED
  60 08 00 48 f6 c8 40 00  00:09:37.154  READ FPDMA QUEUED
  60 08 00 50 f6 c8 40 00  00:09:37.136  READ FPDMA QUEUED
  60 08 00 00 da ec 40 00  00:09:37.100  READ FPDMA QUEUED
Num  Test_Description  Status  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline  Completed without error  00%  4329  -
# 2  Short offline  Completed without error  00%  4295  -
# 3  Short offline  Completed without error  00%  4127  -
# 4  Extended offline  Completed without error  00%  4038  -
# 5  Short offline  Completed without error  00%  3959  -
# 6  Short offline  Completed without error  00%  3719  -
# 7  Extended offline  Completed without error  00%  3630  -
# 8  Short offline  Completed without error  00%  3551  -
# 9  Short offline  Completed without error  00%  3383  -
#10  Extended offline  Completed without error  00%  3294  -
#11  Short offline  Completed without error  00%  3215  -
#12  Short offline  Completed without error  00%  2975  -
#13  Extended offline  Completed without error  00%  2888
#14  Short offline  Completed without error  00%  2836  -
#15  Short offline  Completed without error  00%  2668  -
#16  Short offline  Completed without error  00%  1900  -
#17  Extended offline  Completed without error  00%  1763  -
#18  Short offline  Completed without error  00%  1685  -
#19  Short offline  Completed without error  00%  1517  -
#20  Extended offline  Completed without error  00%  1428  -
#21  Short offline  Completed without error  00%  1349  -
  1  0  0  Not_testing
  2  0  0  Not_testing
  3  0  0  Not_testing
  4  0  0  Not_testing
  5  0  0  Not_testing
Jailer
Not strong, but bad
You have a CRC error count of 49 on that drive. Check your cabling. Also what are you running for a power supply?
rs225
Does anyone do power-cut testing on FreeNAS? Supposedly ZFS should have no problems with it.
larencio88
The Power supply is a Seasonic S12II-620 watts. It's possible the startup current for 12 drives momentarily overloads it. It has been running over a year without any other problems. What puzzles me is how the error message says the corrupted file is uncorrectable, yet the pool is triple mirrored. The file that is corrupted appears to be a system file, not part of my data.
SweetAndLow
Sweet'NASty
Power cuts should not cause problems for zfs. At most you lose the last transaction group. What you're missing here is your system has had these problems for some time now and you are just now noticing them.
This thread has gone on to long. Please read the forum rules and post your hardware specs and freenas version. Also post the output of zpool status.
larencio88
Build
FreeNAS-9.10.2-U1 (86c7ef5)
Bootdrive Intel SSD 710 100GB
Motherboard Supermicro X10SL7-F with onboard SMC2308, IT Firmware
Platform Intel(R) Xeon(R) CPU E3-1226 v3 @ 3.30GHz
Memory 32697MB ECC
Storage 4 Mirrors of 3 x 3.0 TB
  pool: tank
state: ONLINE
        tank                                            ONLINE       0     0     0
[root@freenas ~]#
larencio88
What is the ashift on this pool?
I don't know the command to check that, the install was done using the default settings.
SweetAndLow
Sweet'NASty
Super random question that has nothing to do with the problem.
Makki
I did several, physical, virtual (powering off ESXi "cold") with several TB data on and a read/write load of ~100MB/s: never had any issue.
I'd also suggest to inspect the cabling from the values you've posted.
Michael
P.S.: this was done for DR-testing only, surely the systems all have an UPS but from my experience UPS fail more often than mains power here :) And everything that wasn't tested doesn't work.
larencio88
I am posting a copy of the system log. Scanning through it, these are my thoughts.
  1. The log begins 20 days before the power outage. There are no entries during this time period for disk errors.
  2. Feb 19 22:59:22 the power outage occurs.
  3. The UPS initiates a graceful shutdown.
  4. Feb 19 23:09:22 there is an I/O error during shutdown.
  5. when server powered up 2 days later, Feb 21 20:31:55. Multiple disk errors on Da7.
Random thoughts, Can a bad cable on one drive corrupt a file on the pool. A failing drive itself. A drive without TLER cause a hang.
Maybe this post will help someone troubleshooting in the future.
edit. It looks like the log file is too long to put in with code brackets. (Exceed 3000 characters) Attaching text file instead.
  • Freenaslog.txt
rs225
Thank you. ;) The phenomenon is torn writes with write amplification. Simply put, if I write one 512 byte sector to an AF disk, 8 sectors are at risk of loss if that write fails. Same if a 4K write is unaligned, except 16 sectors at risk. Another scenario is a drive that automatically claims completion of such writes to avoid exposing the actual latency, in the expectation that more will follow to the same track. There are three makes in this pool.
Ashift should be viewable by zdb -e tank | grep ashift
I'm not sure that is a real ZFS I/O error. In any case, even if there was an I/O error, the theory is there should be no corruption to the pool. But if there was an I/O error and corruption, then there is probably a problem in the code, even if the window of exposure is merely 'during a shutdown'.
