Hi all,
I am currently trying to get telegraph working on my FreeNAS but I get a little bit upset. I configured it well and every metric I want came fine (CPU, disks, du, net, ...) but when I want to use the inputs.exec to handle my UPS info, things get annoying.
The binary is installed by hand in /opt/telegraf because the telegraf pkg is not available. With this binary is the config file, an init file and the script I want to use.
The init script looks like (Taken from a reddit thread) :
And I have a Shutdown/Init script in the UI like :
Lastly the script I run for gathering metrics :
Ok now where I am, when I test my script on command line, the formatted line is OK, when I launch the telegraf binary directly by hand in the terminal everything gets fine. But when I use the same command line in the inputs.exec part ... The script failed apparently because he can not execute upsc binary. What did I did wrong ?
!/bin/sh
# $FreeBSD$
# PROVIDE: telegraf
# REQUIRE: DAEMON NETWORKING
# BEFORE: LOGIN
# KEYWORD: shutdown
# Add the following lines to /etc/rc.conf to enable telegrafb:
# telegraf_enable="YES"
# telegraf_enable (bool): Set to YES to enable telegraf
# Default: NO
# telegraf_conf (str): telegraf configuration file
# Default: ${PREFIX}/etc/telegraf.conf
# telegraf_flags (str): Extra flags passed to telegraf
. /etc/rc.subr
name="telegraf"
rcvar=telegraf_enable
load_rc_config $name
: ${telegraf_enable:="YES"}
: ${telegraf_flags:="-quiet"}
: ${telegraf_conf:="/opt/telegraf/${name}.conf"}
# daemon
start_precmd=telegraf_prestart
pidfile="/var/run/${name}.pid"
command=/usr/sbin/daemon
command_args="-crP ${pidfile} /opt/telegraf/${name} ${telegraf_flags} -config=${telegraf_conf} >> /var/log/telegraf.log 2>&1"
telegraf_prestart() {
# Have to empty rc_flags so they don't get passed to daemon(8)
rc_flags=""
run_rc_command "$1"
# $FreeBSD$
# PROVIDE: telegraf
# BEFORE: LOGIN
# KEYWORD: shutdown
# Default: NO
. /etc/rc.subr
name="telegraf"
# daemon
rc_flags=""
run_rc_command "$1"
ln -s /opt/telegraf/telegraf.init /usr/local/etc/rc.d/telegraf; service telegraf start
#!/bin/bash
# Query NUT UPS status and output in InfluxDB Line Protocol
# Usage: ups.sh upsname[@hostname[:port]]
# (same as `upsc`, see https://networkupstools.org/docs/man/upsc.html)
# Sample telegraf.conf config snippet.
#[[inputs.exec]]
# commands = [
# "/usr/local/bin/nut-telegraf.sh ups@127.0.0.1"
set -euo pipefail
IFS=$'\n\t'
function join { local IFS="$1"; shift; echo "$*"; }
declare -A vars=();
# read UPS status into `vars`
while IFS=": " read -r k v; do
vars[$k]="$v"
done < <(bash -c "upsc $* 2>/dev/null")
# exit if empty/unsuccessful
[[ -z "${vars-}" ]] || exit 1
# print a metric in InfluxDB line format
tags=(
ups=${1%%@*}
fields=(
status=\"${vars["ups.status"]}\"
load=${vars["ups.load"]}
battery_charge=${vars["battery.charge"]}
battery_runtime=${vars["battery.runtime"]}
battery_voltage=${vars["battery.voltage"]}
battery_voltage_nominal=${vars["battery.voltage.nominal"]}
input_voltage=${vars["input.voltage"]}
input_voltage_nominal=${vars["input.voltage.nominal"]}
output_voltage=${vars["output.voltage"]}
ups_realpower_nominal=${vars["ups.realpower.nominal"]}
timer_reboot=${vars["ups.timer.reboot"]:--1}
timer_shutdown=${vars["ups.timer.shutdown"]:--1}
time=$(date +%s)
echo "ups,$(join , ${tags[@]}) $(join , ${fields[@]})"
#[[inputs.exec]]
# commands = [
set -euo pipefail
IFS=$'\n\t'
declare -A vars=();
vars[$k]="$v"
tags=(
ups=${1%%@*}
fields=(
time=$(date +%s)
