Teamspeak 3 server help
flash2073
I have followed the steps found in the forums at https://forums.freenas.org/index.php?threads/how-to-install-teamspeak-3-server-into-a-jail.16900/
and done a ton of research into installing TS3 within a jail.
I am using freenas 11 U1, (most current)... I understand jail process/creation/ssh into and have followed steps to the best of my ability but the problem I am getting is I get the error stating teamspeak3-server 3.0.13.6,1 is marked as broken: will not start on FreeBSD 11, bug 212493.
I have been searching for the last couple days and have followed several steps that have been found, but nothing found has taken me further then this error.
I will continue doing things on my end, but am at the point where I needed to reach out and see if anyone might have some ideas of how I can get past this error.
I thank you in advance!
flash2073
Thank you for your help monkey_
I did come across both of those post, and followed steps up to the subversion part. I stopped because I was not sure how to pull/load up that specific port that is shown in the link you posted. I also came across this link https://bugs.freebsd.org/bugzilla/show_bug.cgi?id=212493 which is the exact error that nas is reporting. In either case at this point I'll have to look at how to use a different port. Seems as if the one that keeps getting pulled is this same version of TS that ends up in error.
I also found this https://www.freshports.org/audio/teamspeak3-server/files/teamspeak.in. This seems to be the newest updated info from freshports.
I will go through those steps you showed again and see what I can come up with/where I went wrong and how to pull the specific port.
Thank you again for your help!
