Task Manager FAIL
eea
Replication shows finished but task manager gives error and no real logs to show.
also alerts shows successfully finished. This also occurred in 12RCS
Nick2253
I'm assuming that this is meant to be a bug report. For bug reports, you'll want to use the "Report a Bug" links on the top bar.
Also, it's a huge help if you can explain what exactly you were doing, as well as provide your log files for some more details. It's not clear exactly what you were doing from your screenshot.
eea
I was thinking to file a bug report but I thought I would consult the forums first.
I was running a replication task which shows "finished" however task manager
reports a failure without logs! my alerts report replication task "finished" with
the time if I'm lucky. No way a division by zero should occur. This also occurred in 12RC1
