System power consumption / UPS readout
djdwosk97
I'm using an APC BE750G and I wanted to see what my systems power consumption is under various loads. I ran upsc ups@localhost and here is the output:
Is the current power consumption the ups.load (7%)? If so, is that 7% of 450w -- so 32w? That seems on the low side.
[root@freenas ~]# upsc ups@localhost
battery.charge: 100
battery.charge.low: 10
battery.charge.warning: 50
battery.date: 2001/09/25
battery.mfr.date: 2015/08/04
battery.runtime: 4329
battery.runtime.low: 120
battery.type: PbAc
battery.voltage: 13.8
battery.voltage.nominal: 12.0
device.mfr: American Power Conversion
device.model: Back-UPS ES 750G
device.serial:
device.type: ups
driver.name: usbhid-ups
driver.parameter.pollfreq: 30
driver.parameter.pollinterval: 2
driver.parameter.port:
driver.parameter.synchronous: no
driver.version: 2.7.3
driver.version.data: APC HID 0.95
driver.version.internal: 0.39
input.sensitivity: medium
input.transfer.high: 139
input.transfer.low: 92
input.transfer.reason: input voltage out of range
input.voltage: 121.0
input.voltage.nominal: 120
ups.beeper.status: enabled
ups.delay.shutdown: 20
ups.firmware: 908.W4 .D
ups.firmware.aux: W4
ups.load: 7
ups.mfr: American Power Conversion
ups.mfr.date: 2015/08/04
ups.model: Back-UPS ES 750G
ups.productid: 0002
ups.realpower.nominal: 450
ups.serial: 4B1532P01778
ups.status: OL
ups.test.result: No test initiated
ups.timer.reboot: 0
ups.timer.shutdown: -1
ups.vendorid: 051d
[root@freenas ~]#
