wilhelmkeiserII
- Sep 5, 2017
System specs:
Build: FreeNAS-11.1-U4
Platform: Intel Xeon CPU D-1541 @ 2.1GHz
RAM: 32627 MB
Disks:
1 x SuperMicro 128 GB SATA DOM (boot and system)
2 x Seagate 10GB SATA HDDs (RAID1)
1 x 5100 PRO M.2 480GB SATA (for read cache)
Problems started happening to me last month. I discovered my webGUI was inaccessible but I could ping and SSH into the server. However, my command line would freeze when I attempted to sudo or su to become root. I was able to run zpool status and got the following output on my SATA DOM:
After this happened, I rebooted the server because I couldn't get anything done without root privilege. The SATA DOM showed back up fine on zpool status. During the time it was fine, I upgrade to FreeNAS 11.1 from 11.0U4. However, there does seem to be more issues. There will be days when I notice the WebGUI disconnects and that the server responds to pings but cannot be accessed through SSH. When I plug into the console, I see the system constantly streaming the lines:
Occasionally, it'll have a line saying:
irq301 corresponds to:
And on dmesg, ahci0 corresponds to:
With that, I'm not sure if there's an issue with my SATA controller or my SATA DOM. Any hints on how to dig deeper and get a confirmed hardware error?
RAM: 32627 MB
Disks:
$zpool status -v freenas-boot pool: freenas-boot state: UNAVAIL status: One or more devices are faulted in response to IO failures. action: Make sure the affected devices are connected, then run 'zpool clear' see: http://illumos.org/msg/ZFS-800-HC scan: scrub repaired 0 in 0 days 00:00:04 with 0 errors on Wed Mar 14 03:45:04 2018 config: NAME STATE READ WRITE CKSUM freenas-boot UNAVAIL 0 0 0 1504633393467200437 REMOVED 0 0 0 errors: List of errors unavailable (insufficient privileges)
(noperiph:ahcich1:0:0:0): xpt_scan_lun: can’t allocate CCB, can’t continue
Interrupt storm detected on “irq301”: throttling interrupt source
$ vmstat -i | grep irq301
irq301: ahci0					 129025		 18
ahci0: <Intel Lynx Point AHCI SATA controller> port 0xf070-0xf077,0xf060-0xf063,0xf050-0xf057,0xf040-0xf043,0xf020-0xf03f mem 0xfb412000-0xfb4127ff irq 16 at device 31.2 on pci1
ahci0: AHCI v1.30 with 6 6Gbps ports, Port Multiplier not supported
