Syslog-ng crashes pools, forces reboot
jrp
I configured syslog-ng in the settings - > advanced tab in web Gui by entering the IP address of my Splunk server
I received an error when trying to save the configuration but the configuration did stick.
I received no logs to my Splunk server however.
Several hours later sync routines kicked off and generated sync failures
I ended up receiving 20 some alert emails of which most included references to syslog-ng
Failed to check for alert SyslogNg: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/plugins/alert.py", line 774, in __run_source alerts = (await alert_source.check()) or [] File "/usr/lib/python3/dist-packages/middlewared/alert/base.py", line 223, in check return await self.middleware.run_in_thread(self.check_sync) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1209, in run_in_thread return await self.run_in_executor(self.thread_pool_executor, method, *args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1206, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) File "/usr/lib/python3.9/concurrent/futures/thread.py", line 52, in run result = self.fn(*self.args, **self.kwargs) File "/usr/lib/python3/dist-packages/middlewared/alert/source/syslog_ng.py", line 15, in check_sync p1 = subprocess.Popen(["/usr/sbin/service", "syslog-ng", "status"], stdout=subprocess.PIPE, File "/usr/lib/python3.9/subprocess.py", line 829, in __init__ errread, errwrite) = self._get_handles(stdin, stdout, stderr) File "/usr/lib/python3.9/subprocess.py", line 1593, in _get_handles c2pread, c2pwrite = os.pipe() OSError: [Errno 24] Too many open files
The Gui became unresponsive but managed to reboot over SSH
I removed the Splunk server IP from the syslog-ng configuration and although I received the same timeout error noted above the IP address did get removed.
Has anyone seen this or have had success /failure in sending syslog to an external server?
Thanks in advance
jrp
Ooops, my home installation is bluefin, this one is at the nonprofit I volunteer at which is currently angelfish
