hrayrwannis
- Mar 18, 2023
hello everyone.
Can anyone tell me what is this about? and how to clear it?
thanks,
New alerts:
thanks,
New alerts:
- Failed to check for alert UnencryptedDatasets: concurrent.futures.process._RemoteTraceback: """ Traceback (most recent call last): File "/usr/lib/python3.9/concurrent/futures/process.py", line 243, in _process_worker r = call_item.fn(*call_item.args, **call_item.kwargs) File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 115, in main_worker res = MIDDLEWARE._run(*call_args) File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 46, in _run return self._call(name, serviceobj, methodobj, args, job=job) File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 40, in _call return methodobj(*params) File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 40, in _call return methodobj(*params) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1254, in nf validate_return_type(f, res, nf.returns) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1227, in validate_return_type clean_and_validate_arg(verrors, schema, res_entry) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1233, in clean_and_validate_arg value = attr.clean(arg) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1110, in clean final_value = i.clean(tmpval) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 656, in clean tmpval = copy.deepcopy(v) File "/usr/lib/python3.9/copy.py", line 146, in deepcopy y = copier(x, memo) File "/usr/lib/python3.9/copy.py", line 230, in _deepcopy_dict y[deepcopy(key, memo)] = deepcopy(value, memo) File "/usr/lib/python3.9/copy.py", line 146, in deepcopy y = copier(x, memo) File "/usr/lib/python3.9/copy.py", line 205, in _deepcopy_list append(deepcopy(a, memo)) File "/usr/lib/python3.9/copy.py", line 146, in deepcopy y = copier(x, memo) File "/usr/lib/python3.9/copy.py", line 230, in _deepcopy_dict y[deepcopy(key, memo)] = deepcopy(value, memo) File "/usr/lib/python3.9/copy.py", line 146, in deepcopy y = copier(x, memo) File "/usr/lib/python3.9/copy.py", line 230, in _deepcopy_dict y[deepcopy(key, memo)] = deepcopy(value, memo) File "/usr/lib/python3.9/copy.py", line 146, in deepcopy y = copier(x, memo) File "/usr/lib/python3.9/copy.py", line 229, in _deepcopy_dict for key, value in x.items(): ValueError: too many values to unpack (expected 2) """ The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/plugins/alert.py", line 784, in __run_source alerts = (await alert_source.check()) or [] File "/usr/lib/python3/dist-packages/middlewared/alert/source/datasets.py", line 18, in check for dataset in await self.middleware.call('pool.dataset.query', [['encrypted', '=', True]]): File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1395, in call return await self._call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1355, in _call return await self.run_in_executor(prepared_call.executor, methodobj, *prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1258, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) File "/usr/lib/python3.9/concurrent/futures/thread.py", line 52, in run result = self.fn(*self.args, **self.kwargs) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1252, in nf res = f(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1382, in nf return func(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/pool.py", line 3074, in query self.__transform(self.middleware.call_sync( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1418, in call_sync return self.run_coroutine(self._call_worker(name, *prepared_call.args)) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1454, in run_coroutine return fut.result() File "/usr/lib/python3.9/concurrent/futures/_base.py", line 433, in result return self.__get_result() File "/usr/lib/python3.9/concurrent/futures/_base.py", line 389, in __get_result raise self._exception File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1358, in _call_worker return await self.run_in_proc(main_worker, name, args, job) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1273, in run_in_proc return await self.run_in_executor(self.__procpool, method, *args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1258, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) ValueError: too many values to unpack (expected 2)
