Swap becoming full with unused RAM
HoneyBadger
actually does care
Administrator
You've got a large amount of memory in the laundry queue (7770M) - that's memory that needs to be cleaned up before it's free for use.
What happens if you don't power the VM on?
Do you have the "autotune" feature enabled, by any chance? (If you don't, don't turn it on.)
f4242
Is there a way to clean that memory?
Cannot tell for this specific box. The problem take a fews days to occurs and unfortunately, I can't shutdown the VM for so long. I have another box with same hardware with a lighter workload and with no VM and this problem doesn't occurs. But I didn't had this problem before when running FN 11.2.
Nop, autotune is disabled.
Thank you!
