I've picked up an X10SLL-F on eBay for my build, and I had planned to buy a Xeon 1220 v3 second hand to go in it. However I've seen some discussion about certain bios versions being incompatible so I wanted to check if the chip would work before I bought one. I've been told that the motherboard I've bought previously had a Xeon 1250 v5 in it and it worked - if that's the case, should the 1220 v3 also work fine?
Thanks!
Thanks!
