I have a situation with my onboard video. I have a supermicro x11ssm-f-o MB. When installing and playing around with the console menu on initial install the display was fine and could see the boot and menu. Several times I utilized the vga port to interact with bios and the console menu. I installed a 10gbe intel nic card, went to use the onboard vga port and console menu. There is no video output from the mother board. None at all. Through IPMI I can see it boot, I can SSH or web interface to the freenas machine just fine and load the console menu through CLI. My problem is I'm not well versed in the networking side of things, learning as I go. I don't want to make a mistake and lose all access to the machine, I do not have a direct way to interact except through the network. FYI, the intel 10gbe card was identified fine and showed in the system. If I remove the card or leave it in makes no difference, the video is not displayed. This is not just a freenas issue as I get no post video for bios either.
I have checked all the board jumpers, all in correct position, nothing has changed from when I used it before. I have checked the monitor on another device, works fine. At this point I am wondering, should I buy a PCI card to use to access bios and console menu, anyone know a card that works plug and play? Just need a display, doesn't need anything but vga or hdmi, can be old and cheap. I cant think of any other options. Any input is greatly appreciated.
