I'm about to build a new system for fn, and I would like to use this board. (http://www.supermicro.com/xeon_3400/Motherboard/X8SIE.cfm?IPMI=Y&TYP=SAS)
It has an onboard LSI SAS 2008 controller, and dual Intel 82574L network ports.
Is this board supported in the latest fn build? If not, when will it be?
The SAS controller is the important part, I can add a network card if the onboard ones aren't supported yet.
I will flash the controller with IT firmware, as I don't need the raid functions.
Thank you,
Thank you,
