That's the funny thing aswell.. I put it on my USB had it sitting there.. Tried from the GUI and it broke.. Again.. Not as bad as last time when I hit VLAN by accident it would refuse to come up at all until I re-flashed clean..
After flashing a few times with no luck of connectivity I reloaded my backed up config and everything came back up - this time with a dhcp address?..
Clearing settings as instructed and it bit me again.. I'm on 2.0C ( I think it shipped with this) bios.. 3.19 IPMI.. Hopefully next time will be smooth.. I hope :(..
Edit: Any tips for using FreeNAS GUI integrated IPMI with the SuperMicro boards? I keep getting failures.. I did read the doc but starting to think I'm doing something wrong.. I can get info via ipmitool.. But only failures via freenas GUI..
System Temp | 32.000 | degrees C | ok | -9.000 | -7.000 | -5.000 | 80.000 | 85.000 | 90.000
Peripheral Temp | 30.000 | degrees C | ok | -9.000 | -7.000 | -5.000 | 80.000 | 85.000 | 90.000
CPU Temp | 0x0 | discrete | 0x0000| na | na | na | na | na | na
FAN 1 | na | | na | na | na | na | na | na | na
FAN 2 | 1050.000 | RPM | ok | 300.000 | 450.000 | 600.000 | 18975.000 | 19050.000 | 19125.000
FAN 3 | na | | na | na | na | na | na | na | na
FAN 4 | 1950.000 | RPM | ok | 300.000 | 450.000 | 600.000 | 18975.000 | 19050.000 | 19125.000
FAN A | na | | na | na | na | na | na | na | na
Vcore | 0.872 | Volts | ok | 0.480 | 0.512 | 0.544 | 1.488 | 1.520 | 1.552
3.3VCC | 3.408 | Volts | ok | 2.816 | 2.880 | 2.944 | 3.584 | 3.648 | 3.712
12V | 12.296 | Volts | ok | 10.494 | 10.600 | 10.706 | 13.091 | 13.197 | 13.303
VDIMM | 1.536 | Volts | ok | 1.152 | 1.216 | 1.280 | 1.760 | 1.776 | 1.792
5VCC | 5.152 | Volts | ok | 4.096 | 4.320 | 4.576 | 5.344 | 5.600 | 5.632
-12V | -12.098 | Volts | ok | -13.844 | -13.650 | -13.456 | -10.934 | -10.740 | -10.546
VBAT | 3.120 | Volts | ok | 2.816 | 2.880 | 2.944 | 3.584 | 3.648 | 3.712
VSB | 3.344 | Volts | ok | 2.816 | 2.880 | 2.944 | 3.584 | 3.648 | 3.712
AVCC | 3.424 | Volts | ok | 2.816 | 2.880 | 2.944 | 3.584 | 3.648 | 3.712
Chassis Intru | 0x0 | discrete | 0x0000| na | na | na | na | na | na
