SuperMicro IPMI password reset
bar17
Hello Everyone,
I just put together my brand new server intended for FreeNAS.
It has a SuperMicro X11-SSH-LN4F motherboard /w IPMI.
I promptly logged into the IPMI server via my web browser and decided to change the password of the IPMI server. I use a password manager and followed the character limits mentioned in the IPMI manual. 20 characters, symbols, numbers, letters. It took my password, "WBT+A*3V1^*=a.5Fq7G" when I "modified" the ADMIN account.
Now I can't login username ADMIN with password "ADMIN" or "WBT+A*3V1^*=a.5Fq7GE"
Maybe some of these characters are not allowed but it still took it?
Uggghhhh.
The only tools I see online for resetting the password are to boot using a SuperMicro recovery tool. But I don't have a videocard on this machine....
Any ideas would be greatly appreciated!
bar17
I just got lucky!!!
Tried the password minus a single character.
WBT+A*3V1^*=a.5Fq7GE --> WBT+A*3V1^*=a.5Fq7G
Dropping the "E" worked. I guess it only took 19 characters despite the manual saying 8-20.
Don't worry, I have since changed my password again...
Still curious if anyone knows of another way other than dropping a video card in the machine, attaching a monitor, and booting to a SuperMicro tool.
Jailer
Not strong, but bad
You can boot your server and reset the BMC to factory defaults from the shell.
ipmitool raw 0x3c 0x40
bar17
Thank you Jailer, fortunately I did not have to go down this path, but it is good to know for the future potentially.
William Bravin
hello all
my server is running fine... no issues. However i would have liked to start using IPMI connection to my supermicro and admin and admin as user name and password does not work.
so i read on the forums that i can reset the user name and password through the FreeNAS shell. great
The post suggested that i input ipmicfg -fd in the shell ...simple enough
but when I insert this command in the shell I get
zhs command not found
now i read this post who is suggesting to input ipmitool raw 0x3c 0x40 so i did
and the shell root@freenas2 [~] x
I tried to re-enter the IPMI gui but it still did not allow me access to this service
How do i fix the zsh error?
and
how do i change the username and password of the ipmi through the FreeNAS shell
Thank you all for responding
Patrick M. Hausen
The default for Supermicro is "ADMIN/ADMIN" - capital letters.
William Bravin
Thank you for replying
i tried this and did not work
zis8snbt4p
Wow thanks for this. This just saved my bacon. Anyone else detest the random limitation on passwords? I had created a super hard long password aaaaaaaand it's only 19 chars. Whatever.
For anyone still searching on this topic (I presume now long resolved) the answers to these questions:
at the default shell prompt (which is now zsh) type sh<ENTER>
Now you're at an sh prompt and the paths should work to find ipmitool as originally posted.
I don't think you can. (other than through the Shell tab).
EDIT: All junk. See post from @danb35
Why would you want to change shells for this? ipmitool is in $PATH (specifically, it's in /usr/local/bin), and it will run just fine under zsh. William's problem was that he was trying to run a completely different command (ipmicfg rather than ipmitool), one that is not present in Free/TrueNAS (and indeed may not exist).
...which is exactly what he was asking. The answer is apparently ipmitool user set password 2.
OK, you're right, I mis-read it and assumed it was a path problem.
I'll edit my other post accordingly.
ragametal
@bar17 Thank you!!!!!.
The exactly same thing happened to me. I changed the default password with a 20 character one and when i tried to login with it, the system did not recognize it.
I tried the password again minus the last character and it worked.
Constantin
Vampire Pig
The scary thing is that among the various HW vendors for server gear, SuperMicro ranks among the best and stuff like this still slips through.
Is there a good way to contact SM QA/QC to create a ticket so this issue can perhaps be resolved in the next iteration of whatever IPMI tool SM decides to implement?
Jamberry
I just got lucky!!!
Wow, thank you so much! You saved me from a lot of headaches. I had the same error. Password generator created a 20 char password but TrueNas only accepts 19!
saurav
The password restrictions are likely enforced by IPMI (and not TrueNAS). SuperMicro X11SCL's IPMI (firmware: 1.23.04) has these rules.
Password requirements:
- Require password length: 8 to 20 characters
- Password can not be reverse of the user name
- Password must include characters from at least 3 of the listed character classes
- Allowed character classes
- a - z
- A - Z
- 0 - 9
- Special characters
If I don't follow them, trying to change the password with ipmitool results in an error that says something like "data length limit exceeded".
