Have the Supermicro X11SSH-F Motherboard along with Supermicro 825TQ case.
On bootup the fans spin up as normal and hum along.When getting past the bios the CPU, Case fans continously spin to full and then idle speed for the fans and this variation is 6-8 seconds in between.
I have tried changing the settings on IPMI to normal fan speed but nothing. I am using 4 pin fans throughout. Before it gets past bios (When Crossflashing LSi 9211 Card or loading into usb stick ) it is normal and hums along. Only when getting past bios it continuously spins up and down. The sensor readings on IPMI seem normal and are listed below. The Front panel is continuously blinking red for a overheating issue. Off the top I dont know if there is a separate connection that needs to be made on the Backplane to talk to the motherboard Let me know if I overlooked something My only assumption is the HDD's are cooking up or I missed a separate connection to the motherboard.
Reading
CPU Temp Normal 46 degrees C
PCH Temp Normal 29 degrees C
System Temp Normal 24 degrees C
Peripheral Temp Normal 32 degrees C
VcpuVRM Temp Normal 38 degrees C
