Hi forum,
I am looking for an efficient and above all energy-saving system.
I only use it as storage for music and backups.
The most "expensive" will be Plex.
It should be from Supermicro and I think embedded system will be enough.
Does anyone have experience with such setups?
Or rather, what would you recommend as a minimum?
(Not counting the minimum system requirements).
