I've been trying to choose a motherboard and processor for my upcoming Truenas Core build.
I am completely lost with these different options. I have looked at different xeon-D, Atom and Embedded epyc models.
The more I've looked at these, the more I'm lost with the different options.
Budget: 500€ - 1000€ (motherboard + processor)
Purpose of use:
Home server. Mainly a media server for movies, tv-series and music.
Also any family personal files such as photos etc.
Only NAS functions.
I want to run docker and VM's on a separate proxmox device. In this case, the proxmox device can be used as a "playground"
and the NAS can perform its tasks as stable and reliable as possible.
Because in home use the NAS is just idling approximately 95% of the time and the price of electricity is high today in Europe,
so idle consumption should be as low as possible. No need to squeeze a last drops of power consumption
however. Aim for idle consumption is 50w-100w. (with 6 HDD and possible pcie card(s))
Less is more in this case!
I already have a 24bay 4U rack case with 6gbit backplanes from my previous unRAID build.
What I want:
- Will start with 6 wide RaidZ2
- Server grade hardware (prefer supermicro)
- 10gbit NIC, doesn't matter is it embedder or pcie card if total power consumption is roughly the same. I think SFP+ would be a better option than rj45?
- ECC ram. Propably used (cheap) registered ram from ebay. Minimum 128GB, taking suggestions also for this!
- HBA card (pcie) Propably start with 8i card but want to have an option to swap it to 24i card if I will populate my whole server someday.
What this server should do:
- Powerful enough to serve files to all users and running services without any hiccups. At same time not to be an overkill.
- I would like to have an encrypted pool(s). That might effect to cpu choise?
Is any Atom powerful enough for my needs, should I pick some xeon-D instead?
It doesn't have to be embedded system.
I believe I have found two candidates which meet the given criteria and are very available. Of course, I will accept other suggestions with an open mind!
1. Supermicro X12SDV-4C-SP6F
I am concerned about compatibility since the motherboard is so new. Will SFP28 (SoC) work with Core?
I also couldn't find actual power consumption readings. Does anyone have experience with this?
2. Supermicro M11SDV-4C-LN4F
Idea would be use x16 to x8x8 bifurcation card to add external 10bit nic and HBA. Does this sound a good option?
Taking suggestions for good known bifurcation card.
Bonus question:
Do you prefer embedded or external cards with NIC and HBA? Will it make difference in total power consumption?
Purpose of use:
Only NAS functions.
What I want:
Bonus question:
