Soloam
- Feb 14, 2014
Hello, I've been following this forum for some time, and now I'm going to venture in NAS custom build.
First of all, I'm not going to make a final system, this will be a startup and with time I'll upgrade according to my needs, so my assumptions are:
- Low energy consumption
- Not to noisy
- Store my files shared between laptops, desktop, mobile devices.
- Torrent Download
- Serve Media to my MediaPlayers (no transcoding, just serve the files).
So, with this my idea for beginning system:
MB: Supermicro X9SCA
CPU: Intel Pentium G2030
Memory: (please advice the memory that I'll need, the minimum to get me going and don't over kill my wallet).
PSU: (any advice on a good, but not to expensive PSU? That can suport my system but not to noisy)
Case: (any advice on a good ATX case that is not big very big?)
HD: 3x 1TB Wester Digital Green (I now, its not a lot, but it's all that I have for now and it will have to work for now).
Please note that the plan is to have a system that does not need a lot of initial budget, but with possibility to on the future add extra HD and RAM if needed (for now this 2 components are for the minimum possible).
Other configurations recommendations are welcome.
Thank you in advance
Best Regards
- Not to noisy
- Torrent Download
Best Regards
