CookieMonster
- May 26, 2022
I am new to the NAS world, and I would like to build my first solution. I've been reading a lot, but I am drowning in the sea of information, and I was wondering if any of you, folks, could give me a sense of direction given my situation so that I could start progressing forward with my build instead of to sifting through all the available info for a year+ without any actual progress.
I would like to have a home server with the following features:
I am a broke student, so I am on a budget. I have already ordered two WD Red Pro 18 GB drives to start with. They should ship tomorrow and arrive next week.
I have a 2019 Dell G3 3590 laptop, and I was wondering if I could convert it into a decent NAS/home server.
This model is known for an extremely poor build quality: cracking plastic case, display hinges in this model break after 7 months of use (very common for this laptop), poor battery. So, it's not usable much as a laptop, but it's got capable specs that seem to me to be far better than the anemic CPU, No GPU solutions that you get from, for example, Synology for a crazy amount of money.
The reasons why I am considering are the following:
externally
The main ports of interest are the NVME M.2 due to its massive bandwidth and the SATA port.
Questions:
I was thinking that maybe I could have some kind of external case with removable drive bays like in Synology and then connect the drives inside it either to:
Some final questions:
I would appreciate your help and opportunity to learn from your experience, folks.
Thank you.
- NAS/file server
- Media-server
- Docker support
- VM support would also be nice to have.
- I could save money (as I mentioned, I am on a budget)
- It's a laptop, so energy cost savings should be great
- Built-in screen, should I have issues remoting into it
- It's got quite capable hardware:
9th Generation Intel Core i5-9300H
8GB 2666 RAM (Non-ECC) --> Non-soldered, so can put more if needed
GTX 1660 Ti Max-Q --> Should allow a crap ton of "easy" 1080->720 simultaneous transcoding streams, and probably around 3-4 of heavy duty 4k->720 streams according to Plex GPU comparison chart (which doesn't have my GPU, but it has the non-Ti desktop 1660, and mobile 1660 Ti Max-Q is about 25% slower than a desktop 1660 non-Ti card according to these benchmarks). The 3-4 streams in the worst case scenario of 4k transcoding would be fine for me.
512GB NVME SSD --> Can use for cashing?
HM370 Chipset - supposed to support up to 4 SATA ports
externally
- 1x 1Gb Ethernet
- One USB 3.1 Gen 2 Type-C port with DisplayPort
- One USB 3.1 Gen 1 port
- Two USB 2.0 ports
- One HDMI 2.0 port
- One SD-card slot
- One M.2 slot for NVME (PCIe NVMe 3.0 x4, up to 32 Gbps)
- One M.2 slot for Wi-Fi and Bluetooth combo card (Key E, but not sure how many lanes)
- One SATA AHCI, up to 6 Gbps
Questions:
- Can I somehow connect multiple SATA drives to this one SATA port? Is there some kind of splitter?
- Also, here it says :
SATA Operation - Configures operating mode of the integrated SATA hard drive controller.
Default: RAID. SATA is configured to support RAID (Intel Rapid Restore Technology).
Does it mean I can somehow connect a bunch of HDDs to that SATA port and use them in a RAID array? - I was wondering if there are suitable controllers/adapters that could go into M.2 port and provide several regular full-sized PCIe ports in exchange?
- M.2 (4 lanes for a total of crazy 32 Gbps - if I find a way/adapter/controller to connect to it) or
- SATA (6 Gbs should be enough for an array of platter drives) or
- USB-C (10 Gbs should be enough for an array of platter drives) or
- SS-USB (5 Gbps - probably okay if pulling data only from 2-3 volumes simultaneously)
- Do you think this is a good idea for someone on a budget?
- Will my data be safe without ECC?
- The built-in 1 Gbps Ethernet seems insufficient (even platter drives peak at higher rate than that). What solution would you recommend to add 2.5 or 5 or 10 Gbs Ethernet?
- Would FreeNAS be a good choice for me, or would you recommend to consider other solutions for my use case?
(Important note: I would like to stay open source and away from proprietary stuff.) - Could you please recommend the parts necessary to make this happen?
- How would power management happen for the drives considering that they would probably need to be powered from an external PSU?
Thank you.
