Hi.
I have a dell PE T430 with 128GB ram and PERC H730p on HBA MODE with 8x 3.84TB intel SSD DC S4500.
2x 10Gbpe network interfaces.
I intend to get 2x SSDs 120gb for mirror boot and connect directly on sata ports on motherboard.
My real question is about write cache, should i get a pcie board for nvme? What size is recommended for this setup? My motherboard does not allow pcie bifforcation, so if 2 or more nvme is needed, i will put more m.2 pcie cards, they are cheap.
Any tips on this setup? One large z3 pool is the best choice or is there a better build for size x reliability x speed?
This server is for production xenserver virtualization storage services only. I have another truenas with normal sata drives for backup.
Any sugestions are very wellcome.
Found some info on the forum but most are for home lab and etc...
Thanks.
Thanks.
