Ismael Duarte
- Jun 13, 2011
What does this means? Should I worry about it?
Freenas 9.2.1 Release.
Feb 14 19:00:00 duarte newsyslog[32405]: logfile turned over due to size>100K
Feb 14 19:38:14 duarte kernel: arp: 192.168.1.3 moved from 02:6b:2f:00:10:0a to 00:22:15:a1:db:e8 on epair1b
Feb 14 19:47:14 duarte smbd[33409]: [2014/02/14 19:47:14.520983, 0] ../lib/util/fault.c:72(fault_report)
Feb 14 19:47:14 duarte smbd[33409]: ===============================================================
Feb 14 19:47:14 duarte smbd[33409]: [2014/02/14 19:47:14.521085, 0] ../lib/util/fault.c:73(fault_report)
Feb 14 19:47:14 duarte smbd[33409]: INTERNAL ERROR: Signal 11 in pid 33409 (4.1.3)
Feb 14 19:47:14 duarte smbd[33409]: Please read the Trouble-Shooting section of the Samba HOWTO
Feb 14 19:47:14 duarte smbd[33409]: [2014/02/14 19:47:14.521114, 0] ../lib/util/fault.c:75(fault_report)
Feb 14 19:47:14 duarte smbd[33409]: [2014/02/14 19:47:14.521134, 0] ../source3/lib/util.c:785(smb_panic_s3)
Feb 14 19:47:14 duarte smbd[33409]: PANIC (pid 33409): internal error
Feb 14 19:47:14 duarte smbd[33409]: [2014/02/14 19:47:14.521311, 0] ../source3/lib/util.c:896(log_stack_trace)
Feb 14 19:47:14 duarte smbd[33409]: BACKTRACE: 4 stack frames:
Feb 14 19:47:14 duarte smbd[33409]: #0 0x802950ffd at /usr/local/lib/libsmbconf.so.0
Feb 14 19:47:14 duarte smbd[33409]: #1 0x80146282c at /usr/local/lib/libsamba-util.so.0
Feb 14 19:47:14 duarte smbd[33409]: #2 0x801462a41 at /usr/local/lib/libsamba-util.so.0
Feb 14 19:47:14 duarte smbd[33409]: #3 0x803fab1a6 at /lib/libthr.so.3
Feb 14 19:47:14 duarte smbd[33409]: [2014/02/14 19:47:14.521471, 0] ../source3/lib/dumpcore.c:312(dump_core)
Feb 14 19:47:14 duarte smbd[33409]: unable to change to %N.core
Feb 14 19:47:14 duarte smbd[33409]: refusing to dump core
