strange dnssd_clientstub error messages cause shutdown
nojohnny101
so I did a bit of searching before posting and found this thread:
https://forums.freenas.org/index.php?threads/weird-dnssd_clientstub-error-in-log-on-restart.23180/
from @DrKK
It seems like I am getting similar messages and I do have two jails currently running; plex and plexpy.
Aug 22 11:51:37 axio python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3
Aug 22 11:51:38 axio python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:8 Err:-1 Errno:61 Connection refused
Aug 22 11:51:38 axio python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:7 Err:-1 Errno:61 Connection refused
Aug 22 11:51:38 axio python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:4 Err:-1 Errno:61 Connection refused
Aug 22 11:51:39 axio python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1
Aug 22 11:51:40 axio syslog-ng[1528]: syslog-ng shutting down; version='3.6.4'
I made no configurations changes or restarts which would cause these messages to start. I happen to notice that the server was off and that made me start digging.
Any ideas where to start?
nojohnny101
I'm assuming this has to do with Python but I didn't know that could restart the whole box.
Is my Python out of date?
D
dlavigne
Guest
Were you able to figure this out? If not, what is the exact build version (from System -> Information)?
nojohnny101
I have not had any luck with it though it has not happened again since 8/22/2016. Little disconcerting because I do not know the root cause. Does anything strike you off the top of your head that python could cause a FreeNAS shutdown?
Build:
FreeNAS-9.10.1 (d989edd)
