Noip setup issue
ZodiacUHD
Hello everyone, i setup a noip account and i wanted to automatically update my Ip from my freenas box. I'm having some issues and i need your help. It's not updating.
Here are the logs:
[root@freenas] ~# cat /var/log/messages | grep dns
Jun 15 10:03:30 freenas smbd: dnssd_clientstub DNSServiceProcessResult called with DNSServiceRef with no ProcessReply function
Jun 15 10:03:31 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1
Jun 15 10:03:32 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2
Jun 15 10:03:33 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3
Jun 15 10:03:34 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:6 Err:-1 Errno:61 Connection refused
Jun 15 10:03:34 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:7 Err:-1 Errno:61 Connection refused
Jun 15 10:03:34 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:4 Err:-1 Errno:61 Connection refused
Jun 15 10:03:35 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1
Jun 15 10:03:36 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2
Jun 15 10:03:38 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3
Jun 15 10:03:39 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:4 Err:-1 Errno:61 Connection refused
Jun 15 10:03:39 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:6 Err:-1 Errno:61 Connection refused
Jun 15 10:03:39 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:7 Err:-1 Errno:61 Connection refused
Jun 15 10:03:40 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1
Jun 15 10:03:41 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2
Jun 15 10:03:42 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3
Jun 15 10:03:43 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:7 Err:-1 Errno:61 Connection refused
Jun 15 10:03:43 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:6 Err:-1 Errno:61 Connection refused
Jun 15 10:03:43 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:4 Err:-1 Errno:61 Connection refused
Jun 15 10:03:44 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1
Jun 15 10:03:45 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2
Jun 15 10:03:46 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3
Jun 15 10:03:47 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:7 Err:-1 Errno:61 Connection refused
Jun 15 10:03:47 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:4 Err:-1 Errno:61 Connection refused
Jun 15 10:03:47 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:6 Err:-1 Errno:61 Connection refused
Jun 15 10:03:48 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1
Jun 15 10:03:49 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2
Jun 15 10:03:50 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3
Jun 15 10:03:51 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:4 Err:-1 Errno:61 Connection refused
Jun 15 10:03:51 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:7 Err:-1 Errno:61 Connection refused
Jun 15 10:03:51 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:6 Err:-1 Errno:61 Connection refused
Jun 15 10:03:52 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1
Jun 15 10:03:53 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2
Jun 15 10:03:54 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3
Jun 15 10:03:55 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:6 Err:-1 Errno:61 Connection refused
Jun 15 10:03:55 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:4 Err:-1 Errno:61 Connection refused
Jun 15 10:03:55 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:7 Err:-1 Errno:61 Connection refused
Jun 15 10:03:57 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1
Jun 15 10:03:58 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2
Jun 15 10:03:59 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3
Jun 15 10:04:00 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:6 Err:-1 Errno:61 Connection refused
Jun 15 10:04:00 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:4 Err:-1 Errno:61 Connection refused
Jun 15 10:04:00 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:7 Err:-1 Errno:61 Connection refused
Jun 15 10:04:01 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1
Jun 15 10:04:02 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2
Jun 15 10:09:13 freenas smbd: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1
Jun 15 10:09:14 freenas smbd: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2
Jun 15 10:09:14 freenas smbd: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3
Jun 15 10:09:15 freenas smbd: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:36 Err:-1 Errno:2 No such file or directory
Fatal dyndns server update error for alias, mynas.net.
D
dlavigne
Guest
What's the FreeNAS build version (from System -> Information)?
SweetAndLow
Sweet'NASty
Please provide details so someone can help you. How did you set it up? Screenshots? What have to done to try and fix it?
ZodiacUHD
Not many details to be added really, i set it up via FreeNas's dynamic DNS page in Services -> Dynamic DNS. I put in my credentials such as domain, username and password and that's it. I save the changes, FreeNas says it succesfully started the service but as soon as i refresh the page i can see that the service is not started. As you can see in the logs, that is what i get.
D
dlavigne
Guest
In that case, please create a bug report at bugs.freenas.org that includes your debug (System -> Advanced -> Save Debug) and post the issue number here. Note that the ticket will be hidden until the dev has a chance to review your debug.
ZodiacUHD
Will do, thank you for your time. Cheers.
