Hi guys,
Using 9.2.1.9 x64
I came back to my home today to see my FreeNAS shut down.
It has a UPS connected to it, which is properly configured with the built in UPS feature (from the GUI) which I believe is NUT.
I wanted to check out if the system did shutdown cleanly or if it just crashed after the UPS ran out of battery.
I first checked
/var/log/ups.log
And saw this:
I don't know WTH I'm looking at...
Tryed googling around a bit and couldn't find any "translation" for that...
Then I checked
/var/log/messages
And I saw this:
Then it was down.
I'm not sure what it means, and I'm not sure where else to look.
I did see the SIGTERM, which is I believe a good sign.
What do you guys think?
Thanks!
Using 9.2.1.9 x64
I first checked
/var/log/ups.log
And saw this:
20150304 134404 80 0.0 28 [OB DISCHRG] NA NA 20150304 134904 63 0.0 28 [FSD OB DISCHRG] NA NA 20150304 135308 NA NA NA [NA] NA NA 20150304 152626 21 119.0 0 [OL CHRG] NA NA 20150304 153125 21 119.0 0 [OL CHRG] NA NA 20150304 153626 23 119.0 0 [OL CHRG] NA NA 20150304 154126 25 120.0 0 [OL CHRG] NA NA 20150304 154437 NA NA NA [NA] NA NA 20150304 154437 26 119.0 0 [OL CHRG] NA NA 20150304 154937 29 119.0 0 [OL CHRG] NA NA 20150304 155437 31 118.0 0 [OL CHRG] NA NA
Then I checked
/var/log/messages
And I saw this:
Mar 4 13:53:08 NAS winbindd[3189]: STATUS=daemon 'winbindd' finished starting up and ready to serve connectionsGot sig[15] terminate (is_parent=1) Mar 4 13:53:08 NAS winbindd[4661]: STATUS=daemon 'winbindd' finished starting up and ready to serve connectionsGot sig[15] terminate (is_parent=0) Mar 4 13:53:08 NAS winbindd[3193]: [2015/03/04 13:53:08.370809, 0] ../source3/winbindd/winbindd.c:234(winbindd_sig_term_handler) Mar 4 13:53:08 NAS winbindd[4660]: STATUS=daemon 'winbindd' finished starting up and ready to serve connectionsGot sig[15] terminate (is_parent=0) Mar 4 13:53:08 NAS winbindd[3193]: Got sig[15] terminate (is_parent=0) Mar 4 13:53:08 NAS nmbd[3183]: [2015/03/04 13:53:08.392791, 0] ../source3/nmbd/nmbd.c:57(terminate) Mar 4 13:53:08 NAS nmbd[3183]: Got SIGTERM: going down... Mar 4 13:53:08 NAS nmbd[3183]: [2015/03/04 13:53:08.408339, 0] ../source3/libsmb/nmblib.c:873(send_udp) Mar 4 13:53:08 NAS nmbd[3183]: Packet send failed to 10.0.255.255(138) ERRNO=Network is down Mar 4 13:53:08 NAS nmbd[3183]: [2015/03/04 13:53:08.408460, 0] ../source3/libsmb/nmblib.c:873(send_udp) Mar 4 13:53:08 NAS nmbd[3183]: Packet send failed to 10.0.255.255(138) ERRNO=Network is down Mar 4 13:53:08 NAS nmbd[3183]: [2015/03/04 13:53:08.408496, 0] ../source3/libsmb/nmblib.c:873(send_udp) Mar 4 13:53:08 NAS nmbd[3183]: Packet send failed to 10.99.99.255(138) ERRNO=Network is down Mar 4 13:53:08 NAS nmbd[3183]: [2015/03/04 13:53:08.408530, 0] ../source3/libsmb/nmblib.c:873(send_udp) Mar 4 13:53:08 NAS nmbd[3183]: Packet send failed to 10.99.99.255(138) ERRNO=Network is down Mar 4 13:53:08 NAS upsd[2985]: mainloop: Interrupted system call Mar 4 13:53:08 NAS kernel: . Mar 4 13:53:08 NAS ntpd[2850]: ntpd exiting on signal 15 Mar 4 13:53:08 NAS kernel: . Mar 4 13:53:09 NAS python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1 Mar 4 13:53:09 NAS last message repeated 2 times Mar 4 13:53:10 NAS python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2 Mar 4 13:53:10 NAS last message repeated 2 times Mar 4 13:53:11 NAS python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3 Mar 4 13:53:11 NAS last message repeated 2 times Mar 4 13:53:12 NAS python: dnssd_clientstub ConnectToServer: connect() failed Socket:7 Err:-1 Errno:61 Connection refused Mar 4 13:53:12 NAS python: dnssd_clientstub ConnectToServer: connect() failed Socket:4 Err:-1 Errno:61 Connection refused Mar 4 13:53:12 NAS python: dnssd_clientstub ConnectToServer: connect() failed Socket:8 Err:-1 Errno:61 Connection refused Mar 4 13:53:13 NAS python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1 Mar 4 13:53:13 NAS last message repeated 2 times Mar 4 13:53:14 NAS python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2 Mar 4 13:53:14 NAS last message repeated 2 times Mar 4 13:53:15 NAS python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3 Mar 4 13:53:15 NAS last message repeated 2 times Mar 4 13:53:16 NAS python: dnssd_clientstub ConnectToServer: connect() failed Socket:7 Err:-1 Errno:61 Connection refused Mar 4 13:53:16 NAS python: dnssd_clientstub ConnectToServer: connect() failed Socket:4 Err:-1 Errno:61 Connection refused Mar 4 13:53:16 NAS python: dnssd_clientstub ConnectToServer: connect() failed Socket:8 Err:-1 Errno:61 Connection refused Mar 4 13:53:17 NAS kernel: .
Then it was down.
Thanks!
