kyeotic
- Mar 2, 2023
I've got a VM setup using a bridged network adapter
The bridge has several IPs assigned to it. .10 is being used by TrueNAS for the UI, .12 is assigned to the VM
The router sees this correctly (note the MAC address from the VM)
The weird this is that this works... some of the time. I can ssh into the VM, I can curl from local to the VM, and I can curl from the VM to local. Until I reboot it, and then SSH hits TrueNAS (which produces fingerprints MITM warnings), and things stop working. I can't figure out what gets it working again, but after any reboot it happens again. The one hint I have is that the router warned me that two devices were using the same IP.
Only these two times though, and this was a few days ago. Its been through this cycle at least twice since then, and no more warnings. I have no idea whats going on here.
